Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 11-03-2012, 11:36 PM
Nitro1 Nitro1 is offline
Vehicle: 96 dodge ram 3500. 4x4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Nitro1 is on a distinguished road
Default lost prime overnight
hi all ! It happened again. fuel system lost its prime after sitting 13 hours. This time its not like last time, last year my diesel would start, run for 30 seconds then die, loosing prime. You guy told me to check pre filter fuel heater, and see if the electrical connector was wet with fuel. it was, so i added electrical grease in the plug, and it worked for about a year. tried that trick again but its not working? wonder if that should be changed? this time instead of running for 30 seconds, it just dont start. if i catch it before 8 hours she starts, a little rough but runs and drives fine. replaced fuel filter, but that didn't help. could it be closer to the injector pump. any ideas?
Old 11-23-2012, 05:42 PM
C Kessinger C Kessinger is offline
Vehicle: 1998 Dodge Ram 2500 4x4 diesel
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
C Kessinger is on a distinguished road
I have a 98 with the 24 valve diesel. i had the same problem and found that the fuel heater was leaking while running and causing me to lose prime if i didnt start every day. my fuel heater is on top of my filter assembly and there is a small o ring that was leaking. ive heard of older heaters going out too and being deleted. there is a delete plug for it, but i found the o rings and just replaced mine today. no more leaks.
= Copyright a Network Site =Ad Management by RedTyger
