Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 11-04-2012, 09:50 PM
ArmySoldier22 ArmySoldier22 is offline
Vehicle: 2001 Ram 2500 5.9L 4x4
Color: Blue
ArmySoldier22 is on a distinguished road
Default Engine Stuttering, no throttle response/popcorn sounds from hood
Hey everyone,
I have a 2003 Ram 1500 with a 5.9L. I have had an ongoing issue with my truck. It always starts up fine on the first turn of the key. Except during the first few minutes of running it, I run into the same issue (usually when engine is cold).
The issue is: basically when I put the gas pedal down and there is no throttle response. The engine does not rev in rpm's, instead there are popcorn noises from under the hood. This goes on for about 2-3 min of stuttering and sometimes getting throttle response and sometimes not. Although after that little amount of time the truck runs fine, with only a little delayed throttle response every now and then.
I talked to my local mechanic and he said he thought it may be the fuel pump, so I had him do a fuel pressure test. The truck failed the test, so I spent a little over $300 for a new fuel pump and install. I thought this work fix it, but the problem still continues. Any ideas of what could be the problem? Is there something else that could have affected the fuel pressure test that could be malfunctioning, other than the fuel pump?
Thanks for any advice/help with this!
-Andrew
Old 11-05-2012, 09:14 AM
RamTech RamTech is online now
Rep:1885
Sounds like a clogged up converter to me. Your "mechanic" should have done a back pressure test and I suspect the fuel pressure test result was bogus.
Old 11-05-2012, 10:46 AM
Color: Blue
I was considering cleaning out the throttle body as well. What "converter" are you referring to that may be clogged up??
Old 11-09-2012, 09:00 AM
Rep:1885
Catalytic converter.
Old 11-10-2012, 12:48 PM
Color: Blue
I had the CAT cut off and checked. It passed the back pressure test, and the O2 Sensors look good. Still hasn't fixed the problem. I've also done the following to try to fix this:
-Cleaned throttle body
-Replaced spark plugs
-Replaced Idle Air Control Valve (IACV)
-Replaced Throttle Position Sensor (TPS)
-Replaced Map Sensors
-Replaced Crank Sensor
Any other suggestions? Thanks a lot!
Old 11-10-2012, 12:55 PM
Rep:1885
Next step is to verify the cam/crank timing. You may be able to do this with a scan tool showing the cam/crank difference in the data stream, otherwise, you get to tear into the engine.
Old 11-11-2012, 11:13 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
You cannot judge O2 sensors by how they look. They have a finite lifespan.
Old 12-01-2012, 11:24 PM
major324's Avatar
major324 major324 is offline
Vehicle: 1997 dodge Ram 1500 2WD 5.9
Trim Level: sport
major324 is on a distinguished road
something awry in the computer or as stated the cam position sensor also i found in the past i had the nasty dodge timing chain severly streched and skipped teeth the computer tried to compensate but would not accelerate without a lot of back talk as the computer will only adjust if within a certain range.
Old 07-01-2013, 08:45 PM
RAM2003 RAM2003 is offline
Vehicle: 2003 Dodge Ram
Color: RED
RAM2003 is on a distinguished road
I have the same truck with the same issue. I just replaced the TPS sensor with no luck at fixing the problem. Were you able to fix te issue and if so what do you recommend?
Old 10-06-2013, 02:46 PM
DJFriar DJFriar is offline
Vehicle: 1997 Dodge Ram 1500
DJFriar is on a distinguished road
I had this exact issue on my '97. Replacing the fuel pump fixed it.
