CEL/Transmission HELP - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-05-2012, 02:50 PM
1stdodgeram 1stdodgeram is offline
Vehicle: 1997 dodge ram
Trim Level: larime edition
Color: silver
1stdodgeram is on a distinguished road
Default CEL/Transmission HELP
I just picked up a 98 1500 4wd, For cheap runs great 142k on the clock
The previous owner told me they thought the trans was fried.. Im not so sure
I can drive it when its cold perfectly fine but when it warms up sometimes it wont shift at all stays in 2nd gear It doesnt do it all the time sometimes it shifts great all day other days its a real p-i-t-a, When is starts acting up the cel comes on and the speedo stops working also I ran the codes and got these
p0107-Map sensor
p0500-Vss
p0753-Shift Solenoid A Electrical
p0720-Output Shaft Sensor
p01765-?? No description
Has anyone heard of all these codes coming up at once could there be a main issue that would set all these codes off at the same time or do I need to start testing each sensor-solenoid and replacing
I havent had the time to look over the truck I did check the trans fluid..The dealership I work at doesnt like us working on personal vehicles, So I figured I would see if maybe someone has had an electrical issue causing something like this or is it time to replace all the sensors
Old 11-05-2012, 03:10 PM
Rep:2929
if you just bought it & don't now the history behind it
maybe it is time to do a fluid & filter change
P-1765 TRANS 12 VOLT SUPPLY RELAY CTRL CIRCUIT
When Monitored and Set Condition:
When Monitored: Continuously with the Key on.
Set Condition: This code is set if the voltage detected on the Transmission Relay Control
Circuit at the PCM is different than the expected voltage for 3 seconds.
POSSIBLE CAUSES
read the rest of the website answer below
Read more: 2000 Dodge Ram 1500 Automatic transmission codes P0753, P1765, - JustAnswer http://www.justanswer.com/dodge/24sm...#ixzz2BNQCVqXz
