Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Place your Ad Here!
Old 11-05-2012, 05:23 PM
Sean E's Avatar
Sean E Sean E is offline
Vehicle: 2002 Dodge Ram 1500
Color: Gray
Sean E is on a distinguished road
Exclamation Spark plugs
Ok its time to change my spark plugs. My question is are there any plugs that are great for preformance??? I have a 2002 dodge ram 1500 4.7l v-8
Thanks guy
Old 11-05-2012, 05:39 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Stick with oem, they will provide the best performance on a nearly stock or stock engine. Many of the advertised plugs you see actually hurt performance or make no difference. If you happened to have a lot of mods you can sometimes benefit from a colder heat range or gap changes.
Sean
Old 11-05-2012, 05:53 PM
Sean E's Avatar
Color: Gray
I have a k&n cold air, throttle body spacer,banks power programmer and a custom exhaust... should i still go with the oem?
Old 11-05-2012, 05:56 PM
Resident Technician
Rep:1915
Yes. There is no miracle plug that will give you a HP boost.
Old 11-05-2012, 06:04 PM
Sean E's Avatar
Color: Gray
Alright thanks. you got any tip on what else i could do to get more hp???
Old 11-05-2012, 09:26 PM
snrusnak's Avatar
Rep:1388
I agree with minimal intake/exhaust/tuning mods stick with oem. Usually you go to colder heat range plugs with forced induction, nitrous, etc. Sometimes ignition upgrades can benefit from wider gaps(although oem ignitions are pretty good anymore).
For more power look into airram.com. 2008+ intake manifold is a big upgrade(costly though IIRC). Headers area good option. And of course cams and head work.
Sean
Old 12-02-2012, 01:24 AM
Keiser Blade's Avatar
Keiser Blade Keiser Blade is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport crew cab
Rep:36
Keiser Blade is on a distinguished road
stock plugs for me too
faster, spark plug, upgrade
