Old 11-05-2012, 05:09 PM
Jubbee Jubbee is offline
Vehicle: 2011 Dodge Ram
Color: Blue
Jubbee is on a distinguished road
Default U connect question
I have a 2011 Ram 1500 that has a RES radio in it when I press the u-connect it says (not equiped) is there somewhere I can purchase a fix for this or do I have to go to the dealer?
Old 11-05-2012, 05:13 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
That's what it displays when you don't have the external Uconnect module The Uconnect module is an extra and not included with the RES radio. (at least not for my 2010).
Old 11-06-2012, 09:02 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Go online and look for the Mopar kit PN 82212159, this will be the module, harness, mic and instructions. You'll also want to get the USB / iPod cable PN 82212160. Once the kit is installed , call around to find a dealer to flash the vehicle for code "RSP". Some dealers will try to charge you &100 but it takes about 15 minutes and some will do it for about $50.
Old 11-06-2012, 12:26 PM
Color: Blue
Thanks for the info.
Old 11-07-2012, 12:47 PM
dkerr24 dkerr24 is offline
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
If the final cost is over $200-300, I wouldn't even bother with it. The uConnect system is at best buggy and SLOW AS MOLASSES. Mine takes a good 15-20 mins to read the files on my USB flash drive. And to make matters worse, it RESETS each time you switch off the truck, forcing you to do another 15-20 min scan before you can use the voice commands.
Darin
Old 11-08-2012, 11:17 AM
Rep:73
1) I'm not sure about the system being slow or buggy. I really don't have issues with my system. Yes there are somethings that I would like to be a bit quicker but it's not like it's killing me. I understand the system and also the amount of information that is going on between the module, & phone, iPod or TD. There's actually a lot going on.
2) This can be a thumb drive issue, I have seen the same files on 1 TD read slower than the same files on a different TD.
It will re-read the drive to compare the content. Uconnect doesn't know if you have added or deleted any of the content while the ign was turned off.
How many songs, what is the GB size and what brand TD are you using?
Darin
Old 11-09-2012, 01:13 PM
Rep:14
Hi xsdbs -
It is a 32gb Kingston thumbdrive with ~ 20gb of music, each artist has its own folder in the root of the drive. I've tried with all the artists in a folder called 'music' and just dumping all the artists folders in the root. No difference in speed.
I just wish there was a way to keep the connection between the TB and head unit active even with the key off so that the TB doesn't have to be re-read each time. I wouldn't mind the 20 minute wait if I didn't have to do it but once.
Darin
Old 11-09-2012, 02:26 PM
Rep:2657
xsdbs, i have a question for you
I read on a Wrangler site, one person stated:
-$99 or less gets you a Belkin Aux jack bluetooth adapter. One end goes into Aux, one end goes into a power source, and it's a big round button like the UConnect kit. Phone calls and bluetooth audio the simple way.
could this be true, or do you lose some functions ?
so it won't be taken out of context, here is the post:
duck87 says:
07:04 AM, 09/26/12
For those with an Aux jack, you have a couple of options if you don't want to go through this...
-$5 on eBay gets you a bluetooth audio module that feeds music to your Aux jack. These usually plug into a USB port, not for data but power. Pretty much an instant and cheapest way to stream bluetooth music from your phone
http://blogs.insideline.com/roadtest...adio.html#more
this blog also has a great how to for installing the kit into a Wrangler, he took many pix & the explanation of what & why is in detail
Old 11-12-2012, 08:54 AM
Rep:73
After looking around, I found this Belkin piece.
1) Is it an alternative? Will it work? (yes)
2) Is it a good choice? (in my opinion, no)
3) why not?
A) It isn't automatic, what I mmean is that in order to use it, you have to be in the "AUX" mode in order to have a call go thru the stereo.
B) If you're listening to the radio or other media and decide that you want to make a call,, you need to reach over and switchthe radio to "AUX" mode, place the call. When you're done with the call, reach over and switch back to radio mode.
C) If you have an incoming call, the radio isn't muted and the call automatically routed thru the stereo. You have to swicth the radio to the "AUX" mode.
D) It doesn't have phonebook download, you have to either place the call by your memory for the phone number or pick up the phone, search for the contact, then place tthe call.
E) It's not trully a handsfree system and BT functions are basic with no advanced VR commands.
F) Belkin vs Uconnect, no comparison.
G) yes it is a cheaper alternative but you can still get a ticket for driver distraction with it.
duck87 says:
07:04 AM, 09/26/12
Old 11-12-2012, 01:22 PM
Rep:73
I have the Transcend 32 GB Thumb Drive, it contains 22.4 GB of music files and 5,165 tracks. It's taking about 4 minutes to read and about 4 more minutes for the library to be read and ready for VR commands. When I left the vehicle and came back it took less than a minute to read and then about a total of 8 minutes to use the VR library. In that 8 minutes, Uconnect is comparing the old files with the re read files to see if there were any added or removed tracks as well as making sure that the all the data still matched. You mmay want to look into a different TD. I have a 64 GB Lexar that I'm going to load up and test it also. Now the VR commands will only be supported with libraries up to about 9,500 - 10,000. Past that there are no VR commands, you can make selections maually only.
Hi xsdbs -
Darin
