Dodge Ram Decals
Old 11-05-2012, 11:07 PM
05bee729's Avatar
05bee729 05bee729 is offline
Vehicle: 2012 ram express
Trim Level: express
Rep:26
05bee729 is on a distinguished road
Default 4g cut springs
considering cutting my springs.. 1/4-12/2 coil at a time till it sits right..... any reasons why i shouldnt? has anyone tried it? also are the sway bar end links and panhard bar bracket required for any reason?
05 dumble bee #729 homemade pvc intake. superchips programer. ls1 fbody efans, 100 shot, leaf springs clamped front and rear
Old 11-06-2012, 11:19 AM
TSINND's Avatar
TSINND TSINND is offline
Vehicle: 2014 Ram 1500
Rep:28
TSINND is on a distinguished road
Lots of 4th gen guys have cut springs on here. You should be fine, keep in mind it will settle a little to
Old 11-06-2012, 11:48 AM
Tyggr09's Avatar
Tyggr09 Tyggr09 is offline
Vehicle: 2009 Dodge Ram 1500
Tyggr09 is on a distinguished road
Please get pics as I'm looking into cutting mine also.
Old 11-06-2012, 12:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Many have cut their springs, but most of the stock 4th gen coil springs should not be cut(they are not the correct type that can be cut safely). Some people do it anyway, but I highly recommend against it.
The only type of coil spring that can be cut safely is tangential(the other types are square and pigtail). The rear springs on 4th gens are pigtail on bottom and square on top, so can not be cut safely. The exception to that is if the springs are progressive with tightly wound coils near the top(I know for a fact the rear RT springs are like this....not sure about other models). Technically you shouldn't cut the progressive(tightly wound near the top) square end springs either, but after cutting them the coils are wound so tight they are nearly square ended again. Once you put very light weight on them(barely start to set the truck's weight down) they flatten out and sit in the spring perch safely.
I bought a set of RT springs for my quad cab and cut them as much as I could(I ran out of tightly wound progressive coil) and I got nearly 1" of rear drop. Also, even if I had more coil to safely cut, I couldn't have because the spring was becoming too short to fit. There is nothing that holds it in place other than the vehicle's weight, and if I cut the spring any shorter I'd be afraid of it falling out if I hit a big bump or something that fully extends the axle.
Check out this website, a lot of good info here:
http://www.eatonsprings.com/cuttingcoilsprings.html
Also, NEVER cut with a torch, and NEVER heat springs to let them fall/sag and cool. Doing either of these is a huge safety concern.
Sean
Old 11-06-2012, 03:04 PM
TSINND's Avatar
Rep:28
^^^ great info........................
Old 11-06-2012, 08:05 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I say cut the fronts, 1/2 a coil at a time (1 full coil is about 2"), and buy McGaughy's 2" drop springs for the rear ($200), cutting them to taste. The OE rear springs can't be cut more than 1 coil safely, which is only worth about an inch (trust me, I tried). You don't HAVE to have a panhard bracket, but your axle will be off-center w/ a 2"+ drop in rear. A Spohn adjustable panhard bar will re-center your axle, but it won't fix the geometry problem. Only a relocation bracket can do this (which can only be bought in a kit or fabbed up). You will need shorter end links for the rear. I actually considered going this route, but for $360 bucks I think I'll just get the BellTech kit from Jeg's. It has springs, shocks, end links, and bump stops. I'll just fab my own panhard bracket, unless I can convince BellTech to include one with their kit. If you decide to go the "cut" route let us know how it works out...
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 11-06-2012, 08:59 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
I cut 1.5 colis off the rear for a full 2" drop. No issues on handling or anything like that. Not sure what the danger in cutting more than 1 coil is. There are others that have cut 2-2.5 coils off the rear. I have had 980 lbs in the rear with only about 3/4" of sag from the load.
Old 11-06-2012, 10:01 PM
redramsrule's Avatar
redramsrule redramsrule is offline
Vehicle: 2012 dodge ram
Trim Level: express
Color: cherry red
Rep:20
redramsrule is on a distinguished road
truck looks great
Old 11-06-2012, 10:55 PM
05bee729's Avatar
Trim Level: express
Rep:26
well so much for a cheap drop kit lol.. guess ill just cut the rear this weekend to level it out till i save up for a drop kit.
Old 11-07-2012, 04:23 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Me and dad bought trucks the same night, both 12 Express QC trucks. I did the 963SP bell tech kit, my dads truck got the springs cut and stock shocks. They sit 100% identical and ride and tow 100% the same hauling the same 21' bass boat.
His has a full coil out of the front and two coils out of the rear making a 2"/4" drop like my bell tech. I did remove the bumpstop cups on his front and mine, and I cut his rear bump stop in half.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
