Old 11-07-2012, 04:33 PM
05bee729's Avatar
05bee729 05bee729 is offline
Vehicle: 2012 ram express
Trim Level: express
Rep:26
05bee729 is on a distinguished road
did you buy sway bar end links and the panhard relocate bracket or is that all factory aslo?
05 dumble bee #729 homemade pvc intake. superchips programer. ls1 fbody efans, 100 shot, leaf springs clamped front and rear
Old 11-07-2012, 06:47 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Cut rear springs beyond 1 coil at your own risk. I cut 1 full coil off and I can remove the spring with one hand easily when the suspension is unloaded! I would I imagine the springs would just fall out (when unloaded) if you cut a couple of coils off, and if you get into an off-camber situation while driving they could potentially do the same. Not a good scenario. You could install limiting straps to prevent this, but why? Drop kits are'nt that expensive, and it's not worth f'ng your truck up or killing yourself to save a few bucks. This another reason I'll be going with a BellTech kit, the shocks are shorter to prevent excessive droop in the rear suspension when unloaded, which in turn keeps the spring in the truck where it belongs. Do what you will, but be careful and think it through...
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 11-11-2012, 09:18 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
I have 1.5 off the rear and you would need to jack the truck up pretty far to have the springs fall out. You would have to be going pretty damn fast over a dip and get air in the rear for that to happen. I was actually in the dez this weekend on a dirt road. The trail from the main road was at an angle and went through 1.5'-2' deep rut to get where I was going.
Not trying to fight about it, just telling what I feel and been through
Old 11-20-2012, 05:41 PM
Jon3sgte Jon3sgte is offline
Vehicle: 2012 Ram CC
Trim Level: Tradesman
Rep:30
Jon3sgte is on a distinguished road
I really want to cut mine but reading through various posts I'm leaning more towards not...
Old 11-25-2012, 05:16 PM
Jayincali's Avatar
Rep:95
Any spring will fall out when the suspension is unloaded enough. Here is a shot from the other night, I pulled in at an angle into a driveway and had about 11"-12" of flex on the passenger side rear wheel. No issues with springs falling out.
Old 11-26-2012, 08:29 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That's not true, I've never seen an oem setup where the springs would fall out without some force.
I understand you are comfortable with yours because you won't ever unload your suspension fully, but others need to be aware of the risk.
Sean
Old 11-29-2012, 08:27 PM
Jayincali's Avatar
Rep:95
There is always risk involved when changing the geometry of your suspension from factory to modded. Do as you feel comfortable with, I for one as well as many others are just fine. Like I said before you will not unload your suspension so much while driving that your springs will fall out. Too each their own.
Old 11-29-2012, 08:47 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Have to agree. The OEM spring will never fall out if left alone. I just replaced my springs with a heavy duty coil spring to eliminate rear sag when under load and to get them out I had to jack the truck up by the frame and disconnect the rear sway/shocks then drop the rear axle a bit to get them to come out without a fuss.
My whole opinion on this cutting business is it wasn't designed that way so why modify it? Either replace with something that was built shorter or leave it alone IMO. As said before it's your truck and if you feel comfortable doing it more power to you!
Chrome... in moderation.
Old 12-02-2012, 06:43 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Rep:85
APSTRAM will become famous soon enough
I swapped my stock springs out today for heavier duty ones of the same length. To remove the stock springs all I had to do was lift the back end of the truck with a jack and removed the springs, no disconecting of anything, I just removed the loose springs off their perch and put in the new ones.
Should I be worried about this causing me a problem? The only other change I had made in the rear was new bilstein shocks a few months back.
Old 12-02-2012, 06:46 PM
snrusnak's Avatar
Rep:1385
This is correct. I'm sure they took a slight amount of force to get out though, yes? I had to pry my stock ones out with a long screwdriver(not real difficult). They will not fall out on their own. Imagine if you cut 1.5 coils off your stock springs, then lifted the truck, they'd just fall out on their own.
Sean
