Old 11-05-2012, 10:33 PM
llrecon llrecon is offline
Vehicle: 2002 dodge ram
Trim Level: sport
Color: red
llrecon is on a distinguished road
Default block heater??
Sorry for bringing up the sludge issue but im curious if a block heater would help to prevent the condensation build up. My 4.7 was fine all summer long till the cold weather came and starting to notice the white mayo building in the oil fill tube. Run M1 full synthetic 5w30. Change every 3000. Is the condensation building up anywhere else or just the oil fill tube? Also why not just remove the oil fill tube and put a plate over the hole and move the oil fill to a valve cover. Any thoughts?
Old 11-06-2012, 01:54 AM
Rep:2657
block heaters are for keeping the water in engine from freezing
it helps to keep the oil from turning to gunk a bit too
when i was just old enough to drive in Connecticut, we laid something like the cardboard container that stoves & refrigerators came in under the engine & radiator, it kept the cold from coming up from the ground & causing problems
Believe it or not, cold does NOT enter the engine compartment through the hood, it comes from the ground
when temperatures start getting down to 10 F, a block heater of some kind helps
the heater does not have to be on all night
you can put it on a timer so that it is on for 3 or 4 hours before you have to drive it
for the first 5 miles drive slow, the transmission fluid needs to thin out too
