Old 11-06-2012, 08:48 AM
moparbay moparbay is offline
Vehicle: 2012 Ram 1500
moparbay is on a distinguished road
Default Does anyone have a "Clear Bra" on their truck
Hey all,
I am thinking about putting a Clear Bra on my 2012 Sport to avoid rock chips on the bumper and grill.
Has anyone put a Clear Bra on their truck and can you recommend/not recommend them and why?
Thanks
Old 11-06-2012, 12:14 PM
06Stang's Avatar
06Stang 06Stang is offline
Vehicle: 2014 RAM 1500 Sport
Color: Granite
Rep:40
06Stang is on a distinguished road
I put it on my fenders behind each wheel. Very easy to put on and the cutter cut the templates perfect. I'd recommend it but only if you have precut templates.
Chrysler Jeep Accessories Tech
Old 11-12-2012, 01:56 PM
Scotty85's Avatar
Scotty85 Scotty85 is offline
Vehicle: 2012 Dodge Ram
Color: True Blue Pearlcoat
Rep:79
Scotty85 will become famous soon enough
Where would I get something like that? I was looking into the 3M vinyl stuff that you can't really see. Are there any other alternatives?
Scott
2012 RAM Sport CC Hemi - Photos here:http://www.ramforumz.com/showthread.php?t=132968
Audio Mods - http://www.ramforumz.com/showthread.php?p=1005034
Perf. Mods - http://www.ramforumz.com/showthread.php?p=1005080
Body Mods - http://www.ramforumz.com/showthread.php?p=1005083
Old 11-12-2012, 07:32 PM
I push the skinny pedal
Rep:3298
There are other alternatives but the 3M is the best stuff I've found at a decent price. The cheap stuff will either yellow or be very visible, but the 3M stay the way it should (friend's charger is going on 3 years with no damage or notable change.
Kurtis
Old 11-12-2012, 07:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I put some of it(different brand, can't remember off hand) above the tailgate handle to avoid scratches from the wedding band. Also have it on my buell in places where my jeans rub the frame paint. Works great.
Sean
Old 11-14-2012, 12:26 PM
Scott
I have found both a stick on film from a local truck accessory store that does tinting and linex, but i have also found that my body shop does a spray on coating called Amor Coat that is suppposed to be good stuff. I got prices from $550 for the 3M film to $900 for the spray on Amor Coat stuff. I am told that both option look the same with a thin line appearing at the edge of application. My thoughts are the 3M film as i can remove it later if needed but the spray on is pretty permanent.
Old 11-14-2012, 04:00 PM
snrusnak's Avatar
Rep:1385
Holy crap that much $ for just a bra?
You ought to be able to buy the material for like under $100 I'd guess, and do it yourself. It's pretty easy.
Sean
Old 11-15-2012, 11:31 AM
06Stang's Avatar
Color: Granite
Rep:40
I have a free roll at my shop so I just do it myself. I'll tell ya tough, very very easy to install if you have experience laying film or putting on vinyl decals. Very forgiving just make sure and wet it and clean your hands and the area properly. Like I said though, unless you get it pre cut its really not going to look good. Use a heat gun to lay down any fingers.
Check eBay for the precut templates.
Old 11-16-2012, 03:52 PM
Thanks for the suggestions, not sure yet which way i will go. You guys will know when i know.
