Old 11-06-2012, 12:13 PM
Boseer Boseer is offline
Vehicle: 1998 Ram 1500
Trim Level: Basic
Boseer is on a distinguished road
Default Bogging at shift
Howdy, I'm new to this site and not quite sure how to navigate. I got a 1998 Ram 1500 4x4 318 5 sp, 142000 mi. On occasion when shifting gears it will bog down and sometimes pop then after revving it the thing will be fine. Happens warm or cold no set speed or distance traveled. Idles fine. Any reading I have done seems to point to the TPS sensor as it seems to happen when I let off the gas to shift and the throttle plate changes position. Haven't slapped a code reader on yet. Seen several other posts that suggest a vacuam leak. How do I teel the differance? If TPS how do I align the end of throttle shaft and socket in new sensor? I'm not exactly a too sharp on anything PCM controlled so Please give out some simple advice. Thanks folks. Mark
Old 11-06-2012, 10:04 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Look doen thru the throttle blades and shine a flashlight into the intake. If it's dirty looking, your vacuum leak is a blown intake plenum gasket. A bad TPS wouldn't just act up when you lift to shift.
