Old 11-08-2012, 07:52 AM
Dodgeman5 Dodgeman5 is offline
Vehicle: 2011 dodge ram 1500 sport
Dodgeman5 is on a distinguished road
I live in Saskatchewan so my resources for this kind of thing are limited but I don't think ordering is a problem
Old 11-08-2012, 09:05 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
essex distributing in BC. and im sure any local shop can get it. theres lots of chops in calgary and edmonton aswell
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 11-08-2012, 09:28 AM
Well I'll look into it a little more. I seen phildo's truck with just a 6" lift and no aftermarket shocks and it looks pretty good with his front and back heights.
Old 11-08-2012, 09:37 AM
chadster21's Avatar
Rep:108
heres mine.. im adding a few things to make it a 10'' lift now.
Old 11-08-2012, 09:39 AM
chadster21's Avatar
Rep:108
try again... hope it works
Old 11-08-2012, 10:22 AM
That's pretty nice man. Is that just a six inh with 35's or bigger?
Old 11-08-2012, 10:47 AM
Originally Posted by Dodgeman5 View Post
I am curious if the 6" RCX lift levels a 1500 ram or is this why everyone is running bilstein 1500 shocks?
A 6" RCX kit only rids of 1" of your rake.
your rake after the lift will range between 1.5-2.5" depending on your starting rake point.
To get a truck level, members, like myself use Bilsteins to get the front up.
1.4" will give you a level look which is the middle setting.
But, most want to fully utilize the Bilsteins and get it to 2.1 or 2.75"
Going this route will leave you nose high and this is why we put 1"-1.5" rear coil spacers to lift the rear to level her out.
I had my lift at 2.1 with a 1" rear coil spacer and I had a 1/2" rake. 1/2" rake looks too level for my liking and purchased a 1.75" rear coils spacer to get a 1-1.25" rake.
So....if you are going to get a rear coil spacer, get a 1.5" and set it to 2.1 on the Bilsteins if you want 1" of rake or do 2.75" and you will have a pretty near level truck
Otherwise if no rear coil spacer, set it to 1.4 for it to be level or 0.7 for a 1" rake.
Hope this answers your question
Old 11-08-2012, 11:00 AM
Thanks that did answer. I think for now I will be purchasing only 35's and possibly bilsteins for levelling and a better ride with the lift. If I get the shocks installed and decide to go bigger and higher later then they will be there already so really I think if I get them it's a win win situation.
Old 11-08-2012, 11:34 AM
His does look good in pictures....but bear in mind, flares are deceiving.
I do recall reading somewhere that he also wants to add Bilstiens to level it out and go 37's.
I'd say do it man, even at the 1.4 setting.
I have been through 3 different heights of lift over the past 3 months.
Check out my signature to direct to you the pics of the 8" lift, 11" lift and the current 7.5" lift.
You know what, Ill respond after this with the pics and their settings.
You sir will have a big lift
Old 11-08-2012, 11:39 AM
6" RCX, 2.1 Bilstiens, 1" TGC Rear Coil Spacer on 37" Nitto Trails (20x9, 0 offset)
6" RCX, 2.1 Bilsteins, 1" TGC Rear Coil Spacer, 3" PA Body Lift on 37" Nitto Trails (20x9, 0 offset)
6" RCX, 1.4 Bilstiens, 1" TGC Rear Coil Spacer on 37" Nitto Trails (20x9, 0 offset)
