MOPAR DECALS
Old 11-16-2012, 09:40 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Check out knuconceptz wiring. This is what I run and I used 0 gauge. It helped me out a ton. I bought 15 feet and had about 5 feet left over.
Old 11-19-2012, 10:12 AM
audio1der audio1der is offline
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
Like the others saud; adequate gauge wire, and big 3. Doesn't hurt anything to upgrade other grounds while you're at it.
If that doesn't do the trick for ya, add a second battery before adding a cap.
Two questions;1) is the amp to your subs digital/class D? If you're running a class A/B amp mono THAT will suck current like Jenna Jameson in an all-star movie and there's little you can do to compensate for that except the high output alternator. 2) Is the wire to your amp copper clad aluminum(CCA), or 100% copper?
I run 1600W rms in my car with a 90A alt and have no dimming above idle rpm using huge wire (welding wire; doesn't have to be fancy, just thick copper) and a 2nd batt.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
