United Radio
Old 11-07-2012, 12:17 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
Default 4:10 gears
planing on doin a gear swap in the future, but not sure if i should get 3:90s or 4:10s. i know most will say 4:10s, but my truck is my daily for the most part and i do take long road trips with it.
so for the people running 4:10s and 33" tires, what RPMs are you turning on the highway at 75mph?
Old 11-07-2012, 11:54 AM
I do not know of the RPM's running 4:10 and 33's, but that is what 09/10 RTs run and use.
But the HP is different in your year of ram and the 4th gens so that 4.10 and 33's will probably run different in your setup
Questions...
will you be towing?
lifting?
drag racing (but still having it as your DD)?
Old 11-07-2012, 11:58 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
mph x gear ratio x 336
__________________ x gear ratio trans
Tire diameter
Old 11-07-2012, 12:07 PM
Tire diameter
That is the exact formula I followed....but I went the next size up as those numbers dont factor in any towing....well at least I think it doesn't.
I dont tow much, but when I do, I DO NOT want to feel a huge loss
Old 11-07-2012, 02:29 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I have 4.10's and 33's and I'm at about 2150 RPM at 70. My highway mileage sucks though
Old 11-09-2012, 12:57 AM
mr.lopar's Avatar
Rep:192
Questions...
will you be towing?
lifting?
that and the new rams have different gear ratios in the trans im sure
for the most part it is my daily and do plan on taking long road trips (1300+ miles) and plan on actually off roading it unlike a lot of trucks
wont be lifting it too much if i do, but at that it dont change anything with the gears
i also plan on converting it over to a manual trans when i can find a parts truck with one
