Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 11-07-2012, 02:04 PM
99Rampower 99Rampower is offline
Vehicle: 99 Dodge Ram V8 318
99Rampower is on a distinguished road
Default 318 to 360 swap HELP!!
I have a 1999 dodge ram with a 318 in it. I hae a complete 360 minus the head that i am planning on rebuilding and installing in my truck. All i am going to do is bore it .030 over and put in a mild cam and a good exhaust. My main question is will my 318 heads fit on the 360 block? I know that the 318 has more compression(8.5:1 compared to 7.2:1 if thats right) which is another bonus if it will work another is will the computer work or will i have to swap that as well or will a computer chip compensate for the larger displacement. Any info would be great.
Thanks Phillip
Old 11-07-2012, 05:35 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Thanks Phillip
The 318 heads fit the 360 yes. The compression in the 318 and 360 is 9.1:1 roughly, depends on tolerances. But the compression you should work with is the compression based on the swept volume which is the distance from the piston crown to the deck when the intake valve closes. This is much more accurate, to find that distance you just have to do a little trig very easy. If you want my honest opinion you would benefit from using comp cams 20-604-9 and setup everything so you can have a DCR of about 8.0-8.5:1. If you use the cast iron heads you will want to use a 180 degree thermostat and probably mid-grade fuel, fuel selection will be iffy you have to but it on a brake dyno and calibrate from there just like the engineers (hello) do. But if you do that you will have some serious power, with the proper head flow and precise crank balancing you could see lower to mid 400, with the correct fuel mapping and calibration. All in the calibration.
Oh the stock DCR for a 318 is around 7.7-7.9:1
I never calculated the DCR for the 360, but it's going to be close to the same because they both ask for octane 87.
Old 11-08-2012, 01:15 PM
If i was to use that cam with that big of a lift and duration, what about the rest of the valve train? Springs, lifters, push rods, etc. Also i noticed that the computer would have to be modified. Would an Edge Programmer or something along those lines work or would i have to get the entire computer re programmed?
Thanks Phillip
Old 11-08-2012, 01:24 PM
Resident Technician
Rep:1915
Follow the recommendations of the cam manufacturer for spring guidance. Pushrod length should be measured and appropriate length units installed. I would call several programmer manufacturers and tell them your plans and ask what options they offer.
Old 11-08-2012, 02:04 PM
Ok thanks for the help
Old 11-12-2012, 02:14 PM
ramvan2500's Avatar
Rep:141
Follow what ramtech said, go with the cam manufactures recommendations for valve train. As for the ECM, you can get it programmed. But if you buy the mopar performance ECM it will work perfectly with that cam (can tell you that from first hand experience with that cam and M/P ecm).
Old 12-05-2012, 10:20 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Double check the duration on the after-market cam if you use one as it will have higher lift and duration...meaning there may be a slight advance required while installing the chain and gears to achieve the correct timing.
