Old 11-07-2012, 02:47 PM
Tjthehemi Tjthehemi is offline
Vehicle: 2011 dodge ram 1500
Trim Level: st
Rep:15
Tjthehemi is on a distinguished road
Default I no its been done alot, once more
so I know the tire size thing has been done a lot, but I have read post after post after post and none of them talk about what's the biggest you can fit while still off roading most people say with a2 inch leveling kit, ( which is what I'm going to buy soon) that you can fit 35's but does that mean just driving straight on a flat road or can you go over whoops an jump your truck while still sitting 35s without rubbing or can you only do that with stock fitment 33's? my question is with a2 inch leveling kit what's the biggest size tire that I can of road with , with out any damage to my truck or the tire? I have a 2011 Quad Cab 4x4 st.
Old 11-07-2012, 02:52 PM
Ghostknife's Avatar
Ghostknife Ghostknife is offline
Vehicle: 2013 Dodge Ram
Color: Grey
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:51
Ghostknife will become famous soon enough
Ill save you alot of time and money, dont jump your truck with a leveling kit. You can fit 35s on a leveling kit, but it may rub when flexing.
Old 11-07-2012, 02:58 PM
Trim Level: st
Rep:15
Ya I wouldnt obviously try to jump it with a leveling kit, but I often off road in ocotillo wells California and glamis, and sometimes you had bigger bumps then expected, and I wouldn't want that to happen and then ruin my fender or my tires. in order to climb some of the steeper softer Hills, you have to use momentum and take bumps pretty fast, so what you're saying is 35 would probably rub then?
Old 11-08-2012, 11:55 PM
Ghostknife's Avatar
Color: Grey
Rep:51
im not too sure if they would rub or not on extreme situations like that. You could flex 33s like crazy and not rub though. Maybe someone else should chime in with the same setup
