Old 11-07-2012, 04:07 PM
Niz1500dcrcp's Avatar
Niz1500dcrcp Niz1500dcrcp is offline
Vehicle: 2012 Ram 1500
Niz1500dcrcp is on a distinguished road
Send a message via AIM to Niz1500dcrcp
Default Electronic 4wd question
So, this is my first truck with electronic 4wd. The settings on the knob are 2WD, 4WD AUTO, 4WD LOCK, 4WD LOW.
The owner's manual doesn't specifically state when to use any of these settings. Of course 2WD when it's dry or raining, 4WD when it's snowing or mud or something like that.
I understand 4WD LOW (when I had my 06 3500 Dually, I had shift-on-the-fly 4WD).
Question is, when do you use 4WD AUTO, and 4WD LOCK? Owner's manual states that I can drive in 2WD and 4WD AUTO. Is 4WD AUTO putting the truck into 4WD that's meant for dry roads?
2012 Ram 1500 Sport 4x4 Crew Cab Deep Cherry Red Crystal Pearl
Painted-to-match center console and air vents on the dash; took off the 4x4 badge that was on the tailgate
My email: theoneandonlyniz@aol.com
Old 11-07-2012, 05:15 PM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Correct it is used for when you shouldnt put it in 4WD lock. For example a road that has a light dusting of snow, and it wouldnt be wise to use 4WD lock (high) due to some dry patches.
Just an FYI, keep in mind that if you use the 4x4auto and it kicks in and out (stop and go) then it is a lot of stress on the clutches in the transfer case. Which can lead to premature wear on the transfer case.
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
