Old 11-11-2012, 10:04 PM
jgregg6 jgregg6 is offline
Vehicle: 2005 Dodge Ram 5.7 Hemi
jgregg6 is on a distinguished road
Right on, good to know. Thanks!
Flowmaster exhaust, S&B CAI, DiabloSport tuner, Moes 85mm TB, Rhino Nerf Bars, 20" Moto Metal
Old 11-27-2012, 02:33 AM
Wludwig's Avatar
Wludwig Wludwig is offline
Vehicle: 2003 Dodge Ram 1500
Color: Grey
Wludwig is on a distinguished road
I've noticed I get about a 1.5 mile per gallon increase just by running non-ethanol fuel. But it's getting to be hard to find. My 03 is getting 15.8 I went with the Gforce chip just for the low cost, figured if it didn't work I wasn't out too much lol. I gained about 2.5 from the chip alone, not sure as far as hp gains.
Old 11-27-2012, 01:02 PM
Thanks for the reply!
A quick update I have the S&B CAI at my house right now just waiting to get time to install it and I have a Diablo sportintune in route along w/ black step ups!
Old 11-27-2012, 01:04 PM
Go Rhino Dominator II Cab-Length Nerf Bars, to be exact!
Old 11-27-2012, 04:09 PM
acs0424's Avatar
acs0424 acs0424 is offline
Vehicle: 2007 Dodge Ram 1500
Rep:15
acs0424 is on a distinguished road
Seeing as you're getting a Diablo Tuner this may be irrelevant, but run mid-grade fuel. I switched from 87 octane to 89 octane at the advice of a friend who was a mechanic for years and knows a crap ton about Dodge. I gained a noticeable MPG improvement in the city and highway, enough so that the extra cost of mid-grade was off-set by the MPG improvement, and there's a slight performance gain. So yeah, run mid grade fuel. That's what the manual recommends anyways.
Old 11-28-2012, 02:52 AM
Crowes 05 Hemi 4x4's Avatar
Crowes 05 Hemi 4x4 Crowes 05 Hemi 4x4 is offline
Vehicle: 2005 dodge ram 1500 hemi 4x4
Trim Level: Slt
Crowes 05 Hemi 4x4 is on a distinguished road
When I bought my 05 , I was getting 13 mpg also.... I've changed plugs and wires, nitro fill in my 33 12.50 20 tires, super chip flash pack, flow master , and my k&n cold air intake and throttle body is on the way... Should be here Friday.. I'll let you know the out come... By the way I'm new to the form also... I'll be posting pics soon....
Old 11-28-2012, 03:42 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
The benifits that you experienced are because the engine (Hemi) is designed to run on mid grade (89 octane) fuel not 87 octane. It is perfectly fine to run 87 (per the manual) but you will see a slight decrease in performance.
You're truck is now running as it was designed to do, performance and all.
By running lower octane fuel than the engine calls for, the engine will pull timing to prevent pinging which reduces power.
I don't think that you were implying this and I hope your mechanic friend wasn't either, but running higher octane then the engine requires will not increase performance. For the best performance you want to run the lowest octane that you can get by with. The higher the octane the more resistant it is to ignition which will allow you to run more timing, thats where the performance gains come from (and or higher compression etc)
Edit: I may have typed all that up for nothing as I just saw your last sentence
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 11-28-2012, 03:58 PM
acs0424's Avatar
Rep:15
Haha, yes I do believe it was ultimately for nothing, sorry. Nonetheless, to clarify for future readers, I am not implying you run a higher octane than is recommended. I am implying you run the recommended octane. The reason I mentioned it was because I know a ridiculous amount of people that should run mid-grade but run low-grade because the car will run on it and it is cheaper. I used to be one of them, never thought it really made much of a difference. Now I know.
Old 11-29-2012, 07:38 AM
That's good to know I didn't realize that!
Old 11-30-2012, 05:45 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
As I thought.
It's good info for others that don't know or are unaware.
