Old 11-08-2012, 11:42 AM
moes moes is offline
Vehicle: 2001 Dodge Ram 1500
Color: Sandalwood Gray
moes is on a distinguished road
Default Tuck runs rough after reaching "operating temp"
2001 Dodge Ram, 1500, 5.2L(318 C I), ear Wheel Drive : After engine reaches "operating temp", it runs rough, coughs and sputters, does not accelerate, pings, no more than 1000 RPM otherwise it stalls....However, I let it cool down, it starts and runs just fine UNTIL it reaches "operating temp" and we go thru the same scenario again...
When it first began to act up, I replaced Plugs, Wires, Distributor Cap and Rotor, however, that did not fix it. So, then based on my Buddy putting a Meter on it, I subsequenty replaced the Ignition Pick-Up and the Coil---that has not helped either...
The fact that it acts up when it reaches "operating temp" and runs fine UNTIL that time, I am thinking it is a Sensor of some sort that is subject to ambient and engine operating temps....
Any suggestions/recommendations ?
Old 11-08-2012, 11:45 AM
Rep:1909
This has crankshaft position sensor written all over it but it should be verified with a lab scope before replacement. I recommend only using a Mopar sensor.
Old 11-08-2012, 09:27 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Welcome to the forum,
This forum is full of great looking trucks; packed with great mod ideas and there are loads of knowledgeable and experienced people here.
AND - We all like pix! Got any to share?
Enjoy the Z!
brad
Interested in one of my mods?
Old 11-09-2012, 07:40 PM
Parabol413 Parabol413 is offline
Vehicle: 1998 Dodge Ram
Color: Green/gray
Parabol413 is on a distinguished road
Do you have any codes? If not try giving the crank sensor a wiggle after starting the truck and see if it makes the truck start to foul up when you touch it. They have a magnet in them that can become loose and cause all sorts of problems.
Old 11-09-2012, 09:37 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Check the intake plenum gasket.
Old 11-13-2012, 08:15 AM
Started Truck and wiggled the Sensor, however, engine did not run rough.....
Old 11-14-2012, 11:48 AM
Default 2001 Dodge Ram 1500 Truck---Trouble Codes
Can I determine Trouble Codes without plugging-in a Scanning Tool ?
Old 11-14-2012, 01:04 PM
Rep:1909
Yeah, key dance. Cycle the ignition switch 3 times and leave it on. Count the pulses from MIL to determine codes. A scan tool is still a much better choice because the key dance won't uncover manufacturer specific codes. I would still strongly recommend scoping the CKP sensor. A wiggle test is only good for a wiring issue and won't reveal a pattern that's breaking down.
Old 11-21-2012, 07:53 AM
Smile Replaced Crankshaft Position Sensor
I replaced the Crankshaft Position Sensor yesterday....Did it from under neath the Truck, all with one hand, 2 trouble lights and my Wife helping at times ! Thank God for Band-Aids, patience, "Mirror - on - a - Stick" , "Magnet Stick" 1/2" Open End Wrench, 50 degree temps in my Garage , more patience and the wonderful feeling I got when (after 2 hrs of trying) I FINALLY got both bolts hand-threaded(after I dropped them many times) !!!!
And the best thing is, the TRUCK STARTED right up !!!!!
Today I will bring the Truck up to "operating temp" and "keep my fingers crossed" !
Will let all know subsequently how the Truck performed...
Happy Thanksgiving to all !!!!!
Old 12-11-2012, 05:59 PM
Default Crank Position Sensor was it !!!!!!!!!!!
To RamTech and all other Respondents:
My Truck is running just fine since I replaced the Crankshaft Position Sensor !!!!
Thank you for your input and Merry Christmas to all !!!!!
Dave Moes
