Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 11-08-2012, 03:58 PM
gamecocks gamecocks is offline
Vehicle: 2001 Cummins
gamecocks is on a distinguished road
Default 2004 3.7 issues
So the girlfriends truck has been doing some strange things.
When the engine is cold, put in Drive and press the gas, It stutters. Not all the time but alot.
It has done this so bad it has shut off. She says it feels like stalling out a straight drive.
So I did a basic tune up. Oil change, spark plugs and wires, Air filter....
A few weeks later it threw a CEL, I forgot the P Code but it was a fluid pressure sensor or switch in the trans. It has cleared itself, but now she says the MPG has gone way down.
What else can I do? Im a diesel guy... Fuel Filter?? but Advanced and Orielly's doesnt have them bc its an "unserviceable part"
Edge JWA, DAP 125s, II Phatshaft 62, RevMax built trans, AD 150, Alligator sump, BHAF
Old 11-08-2012, 04:03 PM
Rep:1882
I'm a bit confused here. The 3.7 doesn't have plug wires but it was the only V-6 available in 2004 for the Ram. By your description of the symptoms, I would do a back pressure test to check for a clogged converter. Sensors and solenoids in the trans are serviceable but you'll need to get these parts from a dealer.
Old 11-08-2012, 05:32 PM
Sorry its been a few months. No plug wires, sorry.
Is the fuel filter a dealer only part? And could it cause the problems? Id rather start with the simple things vs going into the trans..
Old 11-09-2012, 09:03 AM
Rep:1882
The filter is built into the pump and I have yet to see one cause a problem but if you want, you can use a pressure gauge to verify pressure and fuel flow.
Old 11-11-2012, 07:33 PM
HemiLonestar's Avatar
HemiLonestar HemiLonestar is online now
Rep:274
Sure all the coils are firing? If they weren't seated correctly its possible you aren't firing on all cylinders. Sometimes these coils just crap out. Resetting the adaptives might also help.
"Big Red"
2006 Charger R/T
