Old 11-09-2012, 04:26 PM
IM4HUNTING
Default 2012 Power Wagon Questions
Head rests tilt forward way to much for my likeing. does anyone know if 2011,2010 Head rests tilt forward as much. If not , will 2011 or 2010 fit as a replacement.( color is black). One more thing, cant find if you can us the lockers in high range or not. I have heard older wagons can only be used in low range. I do not know about 2012 model. I am new to ramrorumz .com I hope to find new people with power wagons. this is my first wagon. traded 2007 mega cab 4x4 1500.
Old 11-09-2012, 05:25 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
Cool
Forgive me, but what hell is a power wagon? Sounds like something that would have wood paneling on it...
Old 11-09-2012, 05:31 PM
Asur Asur is offline
Vehicle: .
Rep:4373
http://autos.sympatico.ca/truck-revi...for-anywhere/4
Old 11-09-2012, 06:06 PM
Vehicle: .
Rep:4373
Many people put the head rest in a vice and bend them to be less forward, but this may brake the chrome on the stems, others have ordered off the web replacement head rest that will fit, do a search on the site and you will find threads that talk about this and other options.
Old 11-10-2012, 12:58 AM
Iamahemi Iamahemi is offline
Vehicle: 2012 Ram Power Wagon
Color: PW7
Rep:58
Iamahemi will become famous soon enough
Headrests are the same in 2010,2011&2012. As stated earlier put them into a vice & persuade them straight. The lockers can only be used in low range. The sway bar disconnect can be used in 4hi or 4low.
2012 PW bright white,Leer cap,Bedrug,2010 rear headrest swap,black Mopar side steps, debadged
Old 11-10-2012, 01:10 AM
Color: PW7
Rep:58
Power Wagon has front & rear locking differentials,electric disconnect sway bar,12000lb Warn winch, 4:56 gear ratio, the bigger 1 ton axle shafts, Alcoa rims with an inner bead lock, Bilstein shocks,softer springs for better articulation, available in ST,SLT & Laramie trim packages none of which have a wood trim option!!!!
Old 11-10-2012, 01:22 AM
Rep:2657
my '09 ram has the forward slanted front headrests too
some people take out the back ones on the '09 & move them to the front seats
they are shorter & fairly straight
i just reversed mine, like others mentioned above
Old 11-10-2012, 01:29 AM
Rep:2657
this is an old style of a POWER WAGON
out in the desert there are several of these sitting out on the ranches
http://www.autoblog.com/photos/legac...ion-sema-2012/
Old 11-10-2012, 12:00 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I found by tilting the seat back a bit it doesnt bother me at all.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
