Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 11-09-2012, 09:06 PM
sxyutcman sxyutcman is offline
Vehicle: 1994 Dodge Dakota V6 3.9L 2WD
Trim Level: Basic
Color: Blue
sxyutcman is on a distinguished road
Default Purchased a 1994 Dodge Dakota for $400 but has Wrong Tranny in it.
I purchased a 1994 Dodge Dakota for $400 Dollars. The truck looks great and has a great running engine, but someone installed a 1994 Dodge Ram 2500 transmission in it. Is there away to make this transmission work in the truck? Maybe changing the pinout of the transmission? The plug types are totally wrong for my truck.....Any help or suggestions would be great.
Old 11-09-2012, 09:33 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Connectors should be the same. Sounds like you may have a 1996 or newer transmission when they went to an electronic valve body. You're not gonna make it work with your setup.
Old 11-10-2012, 01:48 AM
Rep:2657
i know one of my friends had a 2004 3.9L Ram engine that threw a rod though the case
it was mated to the OEM standard stick transmission
He took a 2009 Jeep engine, that had been rolled over, also a 3.9L & put it in his 2004
he did have to swap things like the timing chain parts, all the sensors, & the complete intake manifold, & maybe a couple other things
It ran like a champ
if the engines are the same, i would have to believe that standard shift transmissions would have to be the same way
Old 11-10-2012, 01:47 PM
Rep:85
No such thing as a 2004 or 2009 3.9 V6. There was a new 3.7 V6 introduced model year 2002, totally different animal.
Old 11-10-2012, 01:49 PM
Rep:85
Can you describe how the pin-outs are different?
Old 11-18-2012, 09:05 PM
Trim Level: Basic
Color: Blue
Here are all the numbers on the transmission that is in the truck
564971 2 A5 B3
P52118782 AG823455 DATE 12-21-00
this is all I have to go on.....Does this help?
