Old 11-10-2012, 09:50 AM
omega1972 omega1972 is offline
Vehicle: 1998 Ram 1500 2WD
omega1972 is on a distinguished road
Default 98 Ram 1500 Tranny Pans
I have a leak in my tranny pan on my 1998 Dodge Ram 1500 2WD 318ci
I'm looking for a new pan to replace the old one. My question is can I use a universal pan as advertised on mny sites? Seems like the OEM cast aluminum are like $300 where as the universal steel ones are like $40.
Thanks
Old 11-10-2012, 03:11 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Yes and no. The bolt patter comes from an earlier non-overdive model, so it will bolt up, but the overdrive models require a deeper pan for a couple more quarts of oil. For example, you most likely have the 46RE transmission, which can trace it's origins all the way back to the 3-speed 727. Same bolt pattern, same gasket. While the deeper overdrive model makes a nice deep sump upgrade on a performance 727, you don't want to use a standard 727 pan on the 46, even though the bolt pattern is the same. I don't think it'll fit anyway as the valve body on the overdrive model needs more room for clearance anyway. Before the overdrive model, we had to pay a lot more for a deep sump 727 pan, but now any OD pan works great on the pre-OD's. Just make sure it's for the correct OD model. There were 2 basic pan designs/ transmission designs from that period: the 904/500/42/44 (smaller) and 727/518/46/47 (bigger). They do not interchange pans between the two. So, now you see why it's yes and no. Those aftermarket aluminum pans have always been steep $$$ compared to stamped steel.
Old 11-11-2012, 01:07 AM
Goatboy's Avatar
Goatboy Goatboy is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Economy
Goatboy is on a distinguished road
Id take it to a local metal fab shop and have em patch / weld it. You might pay 25 bucks for this instead of the $$$ for a new one.
Trinity Dairy & Pack Goats http://trinitydairygoatfarms.webs.com http://trinitypackgoats.webs.com
Old 11-11-2012, 09:36 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I have a stock 46 re pan that is rust free for 25 bucks plus shipping. It will work on a 46 rh as well but will be deeper than the stock pan.
Old 11-11-2012, 11:01 AM
Parabol413 Parabol413 is offline
Vehicle: 1998 Dodge Ram
Color: Green/gray
Parabol413 is on a distinguished road
I looked at a few wholesale mopar parts sites and the tranny pans seemed like they were only around 45-50 bucks. I'm thinking of doing mine if I take the old one down to change fluid and filter since my current one is starting to rust pretty good.
