Old 11-10-2012, 10:31 AM
Jolley's Avatar
Jolley Jolley is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Tan Pearlcoat
Rep:33
Jolley is on a distinguished road
Default Got a question about stance
Im wanting to put 35" toyos on my stock chrome clad rims. I will probably level it but my question is. I want to have a wide stance. I want y tires to stick out and my guess is to put wheel spacers on. And if so how much of a spacer. I can't out a lift on because of my budget. So why is the best way to get a wide stance. Thanks in advance
10' Laramie/35 Mud Grapps/Wheel Spacers/Level/Straights w/ 4" tips/8K HIDs/Bull Bar/22" Led Bar
Old 11-10-2012, 11:20 AM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
spacers will work but i would recomend wheels with a negative offset good spacers r almost as expensive as wheels and i would personally rather have sweet rims
Old 11-10-2012, 11:25 AM
joelwalls's Avatar
Trim Level: sport
i have a 35x12.5 on stock twenty with 1/4 inch spacer and they stick out pretty far now im stuck with the decision of rims or bushwacker fender flares to keep from chuckin nasty crap all down the side of my truck
Old 11-10-2012, 04:59 PM
Jolley's Avatar
Rep:33
Do you have a pick like from the side to how how much they stick out?
Old 11-10-2012, 05:27 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
you will definitely need a level to fit those tires, and if you put to much of a spacer the tires will rub on the fenders
Old 11-10-2012, 11:52 PM
Rep:1804
Here is my rake on it.....
1) if you don't have the cash for new rims with a better offset (negative), wheels adapters hat are hub centric is a way I'd go.
It's not something I'd do, but if cash was an issue, I'd probably do it.
You'd need at least a 1.5" to get a good stance that works with your stock lugs.
2) get rims in either 20x9 with a -12 offset to 20x10 with either a -12 or -24 offset.
-12 on a level will have the wheels stick out by 1.5"
Old 11-11-2012, 01:27 PM
joelwalls's Avatar
Trim Level: sport
this is mine wiyh 1/4 inch spacer
http://i1057.photobucket.com/albums/...s/d0221dfc.jpg
Old 11-11-2012, 10:46 PM
Jolley's Avatar
Rep:33
Is this what your talkin about
Old 11-12-2012, 10:28 AM
Rep:1804
Correct!
This is also what JHinkle has as well.
I believe you ram use the 9/16 lugs vs the 14x1.5 us '12 uses.
Just make sure it is hub centric to your hub. I think our hub is 77.8mm!?!
Make sure to check it every few months to make sure its still torqued.
The reason why you want hub centric is you want the weight on the hub vs the lugs.
Going out 1.5 or more will put added weight and stress and is the reason why its better on the hub.
You may be able to get away with a simple 1/4" spacer, but I have only seen them ran with 295/60/20 and 295/65/20 and some of them had rub at full lock.
JoelWall ^^^ above is using a 1/4" spacer with his 35x12.5. If he is having zero rubs without minor trimming, then go his route.
Anything more than a 3/8" spacer, you will want a wheel adapter as the stock lugs wont grab anymore.
Wheel adapters allow you to use your stock lugs.
Why I say to go 1.5" is because I think your stock lugs will not go in all the way if thinner.
I hope someone who is using a wheel adapter can chime in.
Old 11-12-2012, 07:45 PM
joelwalls's Avatar
Trim Level: sport
correct zero rub even at full lock
