Old 11-12-2012, 10:43 PM
Originally Posted by joelwalls View Post
correct zero rub even at full lock
There you go, OP
Old 11-13-2012, 11:17 PM
Jolley's Avatar
Jolley Jolley is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Tan Pearlcoat
Rep:33
Jolley is on a distinguished road
well guys i just ordered a rough county 2.5" leveling kit and some rough country 1.5" spacers, just have to get the toyo's this weekend and maybe have it all put together next week sometime
10' Laramie/35 Mud Grapps/Wheel Spacers/Level/Straights w/ 4" tips/8K HIDs/Bull Bar/22" Led Bar
Old 11-15-2012, 08:33 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
the mt tires i have are durun not toyo same tread pattern but a little smaller side bitters u may have to watch for that but with 1.5 spacer u should be good to go
Old 11-15-2012, 09:16 PM
seandanger's Avatar
Vehicle: 2011 Dodge Ram Sport
Rep:30
you will probably already know this but in 2011 they switched to a 9/16 wheel stud might want to check you spacer listing
Old 11-15-2012, 09:18 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
im not familiar with the RCX 1.5" wheel adapters however as long as they are the correct hub centric size they should work out ok, i myself use the BORA wheel adapters, and many many members and customers use them as well and i have not heard anything negative about them post up some pics of the RCX adapter when it gets in, and if you dont mind how much did you give for a set of 4 from RCX?
Thanks
Jeremiah Hinkle
Old 11-15-2012, 09:20 PM
seandanger's Avatar
Rep:30
i had some i bought off ebay i ran them on stock wheels till i upgraded and got new rims mine were $120 1.5"
Old 12-21-2012, 09:58 AM
FOZMAN11 FOZMAN11 is offline
Vehicle: 2011 Ram
Color: White-Gold
FOZMAN11 is on a distinguished road
Do you have a level on your truck to get no rub or you stock? If level whats your set up? Got pics to share? TIA
Old 12-22-2012, 12:32 PM
joelwalls's Avatar
Trim Level: sport
im runnin bilstiens up front maxed 2.8 1.5 rear spacer 1/4 inch wheel spacer
Old 12-22-2012, 12:34 PM
joelwalls's Avatar
Trim Level: sport
man i need to take some pics or the truck every time someone asks for a pic i post the same one and it is on a bit of a hill but there is still some rake to it with the 1.5 rear spacer
Old 12-22-2012, 12:59 PM
Vehicle: 2011 Ram
Color: White-Gold
Thank you for the pic and info.
