Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Old 08-17-2013, 12:38 PM
bam2880's Avatar
bam2880 bam2880 is offline
Vehicle: 2013 dodge ram
bam2880 is on a distinguished road
Default New engine oil
Anyone know what engine oil comes in new rams with the hemi motor?
Old 08-17-2013, 12:57 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is offline
The Sound of Eight Hooves
Vehicle: 2013 Ram1500 4x4 8HP70 3.21LSD
Trim Level: Lone Star Quad Cab
Rep:616
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
the 5.7 Hemi with MDS uses 5w20. I believe that Mopar uses Pennzoil but not sure whether its Pennzoil Platinum or some other kind.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 08-17-2013, 07:15 PM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Very difficult to determine
People might believe it's one brand or another, synthetic or conventional, a certain weight, grade etc. But unless someone actually observes what the factory fill is; it's very difficult to determine.
It's quite easy to imagine some supply side assembly line variables where there is a different factory fill oil from time to time.
It's of very little consequence anyway. If you want a good "break in" - change the oil FILTER once or twice to capture any tailings or unwanted metal fragments
Top off the oil after filter change. Then at 1000 - put SYNTHETIC oil in. There is virtually no engine wear with synthetic oil.
Old 08-17-2013, 07:24 PM
tev9999 tev9999 is offline
Trim Level: Outdoorsman
Color: Maximum Steel
Rep:39
tev9999 is on a distinguished road
Actually it is highly doubtful. The Production Part Approval Process is quite complicated, as are engineering change processes, for every single component of a vehicle. Even minor process changes three tiers deep in the supply chain will cause massive headaches for approval. If it is not approved, it is not going on/in the vehicle. Now there may be multiple suppliers approved, but it is not like they are going to send someone down to the local Autozone to pick up a pallet of whatever they have handy.
Old 08-17-2013, 07:28 PM
Piston Slap's Avatar
Piston Slap Piston Slap is offline
Rep:42
Piston Slap is on a distinguished road
Shell/Penzoil, according to allpar.
Old 08-17-2013, 08:31 PM
Trim Level: RT
Rep:136
Default That still doesn't explain it
No one suggested employee errands to AutoZone. You still don't know precisely what oil is your factory fill is unless you have a document, description, assembly tag etc.
Know way to know unless there is full traceable documentation.
Old 08-17-2013, 08:59 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Which is one reason I changed my oil & filter at 500 and then again at 1000 miles. At a 1K I added synthetic.
