Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 11-11-2012, 10:59 PM
DE2500raMMAgnum DE2500raMMAgnum is offline
Vehicle: 2000 Dodge Ram
Trim Level: SLT SPORT
Color: Brilliant BLack
DE2500raMMAgnum is on a distinguished road
Default 92 Magnum Transmission
All I need to is to know what the actual transmission is that is in a 92 dodge d150 2 wheel drive with the 318. I've been told it's from 91 to 95 but just wanna check in on it and see what everyone says. I really just need to know if its a 46rh or a727 or what ever. Can't find a thread about it so figured I'd ask. THanks.
Old 11-12-2012, 02:19 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Being a '92 model, it should be the A518 with lock-up converter. 518's through early 1991 were non-lockup models. By '93 they'd been redesignated the 46RH. Being a lockup model, look for the 518/46RH from 1992-1995. The non-lockup version will work also. Computer might throw a code, but it'll run fine.
Old 04-06-2013, 10:01 AM
The War Wagon's Avatar
The War Wagon The War Wagon is offline
Vehicle: 1992 Dodge Ramcharger
Trim Level: LE 150
Color: Black & Grey
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Rep:31
The War Wagon is on a distinguished road
Send a message via Yahoo to The War Wagon
Lightbulb
Check your code on your firewall - should look something like this;
Or, if your tag on the front lip of the hood is still good & legible, it'll tell you too.
Even tells you if you HAVE the lock-up torque converter or not!
Hope that helps!
'92 Dodge Ramcharger... a work in progress...
'07 Jeep Commander... tow vehicle... :-p
