Old 11-12-2012, 10:19 AM
Augy Augy is offline
Vehicle: 2012 Ram 1500 ST Express
Augy is on a distinguished road
Default 2012 backup camera install help, looking for Reverse Lamp wire
I have installed a DD head unit with a backup camera in my 2012 Express. The camera works great but I have to set the monitor on the head unit to "Camera" to see the camera's input. To have it automatically switch when I put the truck in reverse, I need to send a trigger to the Head Unit. The instructions say to connect into the Reverse Lamp Lead. Does anyone know where I can find that wire in the cabin or under the hood so I don't have to run a new wire all the way back to the rear bumper? Thanks.
Old 11-20-2012, 10:48 AM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
Take your tail gate down, on drivers side in the tail light there are 2 hex bolts undue them and take your tail light off then the bottom light in there is your reverse light. Tap into the positive side and good to go. I did this sunday for my light bar and no problems. You just need to be careful when you re-tape it make sure its tight and you get a full seal
Old 11-21-2012, 04:00 PM
Thanks! I'll have to get some wire and get this done. Was hoping to find something up in the cab but it looks like I'll just have to run the wire back there after all.
Old 11-21-2012, 06:23 PM
Worked like a charm. Thanks!
Old 11-23-2012, 10:54 AM
Rep:40
great, i didnt realise you needed on in the cab, I read it to quick. There is one there but if its done now your good to go. Glad to help
Old 11-26-2012, 05:17 PM
EarthquakeMcgoo EarthquakeMcgoo is offline
Color: Pearl Blue
EarthquakeMcgoo is on a distinguished road
If you have a seven pin connector for the trailer hitch the center lead is the reverse. i "believe" the color is violent.
