Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-12-2012, 11:02 AM
paduv9 paduv9 is offline
Vehicle: 2002 Dodge Ram 1500 4x4/5.9
Trim Level: LTD
Color: Beige
paduv9 is on a distinguished road
Default Overheating at times
My 2002 Ram 1500, 4x4, Quad, 5.9, (90k miles) overheats when I put any type of substantial load on it, like a trailer or a boat. However, otherwise, when the weather is cool (below 75 degrees) it does fine as a daily driver. Here are some related issues:
  • I lose about a gallon of antifreeze every two weeks or so, but I can't find any leaks, but I can often smell antifreeze.....and this is when the engine is running at normal temperatures.
  • I can't find any anti freeze mixed with the engine oil.
  • Thermostat is new and water pump and radiator seem to be operating normally.
Can anyone tell my what the problem might be? I was thinking I might have warped one of my heads, but again, I am not seeing a anti freeze mixed with the oil.
Thanks
Old 11-12-2012, 01:59 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
You are probably burning the anti-freeze. I'd say either a blown head gasket or a cracked head. I don't know if the infamous plenum gasket would cause this. Gentlemen?
Old 11-12-2012, 02:21 PM
Rep:1890
Start with the simple stuff before you go tearing into the engine. have the cooling system and cap pressure tested. This will reveal any leaks and/or a bad cap. I've seem caps that look to be in good condition allow a coolant loss similar to the one you describe.
Old 11-12-2012, 09:32 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
You're not towing with overdrive on, are you? Ditto on radiator cap. Hopefully not a cracked head, but it's on the list.
