Old 11-12-2012, 12:54 PM
Kelzan Kelzan is offline
Vehicle: 2012 Ram 1500
Trim Level: Laramie Longhorn
Rep:12
Kelzan is on a distinguished road
Default More newbie lift questions
Hello Everyone,
I have been reading a lot of posts about lifting our trucks and i just had some questions?
I am thinking of going with a Rough Country 6" lift with Bilstein 5100's. Now i read a post of fastNugly's saying that if i put on the 6" lift and set the Bilsteins to 1.4 that the truck should sit level? Is this correct? I don't really want to do rear coil spacers as i think the 6" lift alone will be plenty.
Also with it lifted up will the 5100's for the rear still work? I was thinking of ordering all 4 from Essex Distributors.
I am also thinking of going with Fuel Hostage 20x10 rims with 35" Toyo muds or Nitto Mud tires. What would i need for offset and backspacing? I want the tires to stick out a bit but not too much. I was looking at SD wheel corp and it says you can get them in -24, -12mm and a backspace of 4.5, 5"
Thanks in advance for any advice you can give me.
Tim
Old 11-12-2012, 02:34 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Originally Posted by Kelzan View Post
Hello Everyone,
Tim
Bilsteins set to 1.4 will put your truck almost level I do believe fast still has a 1 inch rear coil spacer though so you might be a little nose high if u do this, as far as bilsteins go adjustables in the front and monotubes in the back, I have a shock upgrade kit here ramforumz.com/showthread.php?t=124772 it includes the front and rear Bilstein 5100's for 415$ delivered to your door.
Wheel offset will depend on what kind of flares you are going to run, oem flares - 12mm would stick out just a tad, pocket flares with-12 would be flush or slightly tucked, - 24mm looks real good with oem and pockets.
Hope this helps ya out
Old 11-12-2012, 03:07 PM
Rep:12
Thanks for the reply.
I am in Canada so is that still $415.00 to my door for the billsteins?
I will also just be keeping the oem flares on. So I guess I need to start searching for pics of the -12 and -24 on some trucks. Anyone have pictures they can share in this thread of 20x10 wheels with either of these offsets?
Thanks
Old 11-12-2012, 04:03 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Thanks
To Canada your looking at roughly 80 for shipping plus the taxes at the border
Old 11-12-2012, 04:40 PM
Rep:12
No worries. I can get them here in Canada for 434.00 with free shipping. Thanks anyway.
Old 11-12-2012, 05:56 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
That's pretty good for up there I would definitely go that route , make sure u have the right part numbers for the front and the rears as they are 2 different shocks, and not interchangeable with each other.
