Old 11-12-2012, 07:21 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Default Thoughts/experiences on dumping after axle/hidden exit exhaust
My truck came with dual tips ran out the side behind the rear tires. I was under there looking around the other day and noticed that the passenger side was rusted where the tip was welded on. A few wiggles later and my truck now only has one exhaust tip, lol. I really like the clean look of not being able to see the exhaust so I was thinking about dumping it under there somewhere after the axle. Plus, we are trying to save money to sell our house and buy another one and it would be relatively cheap to have a couple of turn-downs welded on. I know it will be louder inside the truck but I'm not worried about that. My concern is the effects of dumping the exhaust out under the truck bed, specifically rust and corrosion.
What do you guys think? Here's kinda the options I am thinking....
1) Dump it. Either right at or after the axle or maybe actually back near where the tips should start. Either way, under the truck is under the truck so I don't think it would make a huge difference which place I dumped it.
2) Single exit on each side IN FRONT of the rear tires. This one just came to me and I'm not sure what it would look like. It should be relatively easy though because the muffler ends right there in that area.
3) Just break down and put new tips back on it.
Thanks for your thoughts and advice!
Old 11-12-2012, 08:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Dumped near the end of the truck should be fine. Only issue would be with excessive idling you'd get a lot of exhaust under there.
Sean
Old 11-12-2012, 08:41 PM
Danzanzio's Avatar
Danzanzio Danzanzio is offline
Vehicle: '05 Dodge Ram
Color: Atlantic Blue
Rep:86
Danzanzio will become famous soon enough
I have mine dumped and it's definitely clean looking but I'm about to change it to cowboy cut straight piped. But I've had my Cherrybomb dumped inches after the cab and I haven't seen any negative effects (rust etc.). The other thing that bothered other people, not me, was the smell of exhaust being stronger right outside the truck. But I never had any smells inside the cab. Just my .02, hope it helped
Old 11-12-2012, 08:52 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Either way is great.
Old 11-16-2012, 09:33 AM
Rep:367
Thanks for the replies. I'm supposed to be taking it to have something done around lunch today and I still haven't decided, lol. I like the no exhaust showing look but I'm concerned about the rusting/corrosion thing, especially with the older third gens having bedside/fender well rusting issues already.
Old 11-16-2012, 10:20 AM
snrusnak's Avatar
Rep:1385
just do it basically like stock but cut it back an extra 4 inches or so. Won't be able to see it but won't trap the exhaust under the truck.
Sean
Old 11-17-2012, 01:34 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
dump it post axle, it's alot quieter than you think..plus you will lose pipe resonance (drone)
