Place your Ad Here!
Old 11-13-2012, 12:07 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Default Complete differential failure due to pinion nut.
Well, good thing I'm a car guy and know what gear whine sounds like.
Had my RAM in a few months ago for a leaking pinion seal. Had them check the nut - said he snugged it up. Whatever that means.
Three months later, I start getting gear whine/whirring a day ago. Drove it to the dealer last evening (noise got progressively worse).
Dealer called me back today to tell me what I already knew. Problem is, they don't even have notice of the recall yet from Chrysler (the M34 recall for pinion nut). So, their solution was to order a new gearset and replace them, the shims, everything. I said that's not going to work.
On the phone with Chrysler corporate right now. Will let everybody know how it goes.
So far, Chrysler is telling me that the initial build date range they sent out in the M34 recall may be broadened. Well yea, I'd think so - my truck was 4 months beyond that build date range and this is the second diff issue I've had.
More to come.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2012 Jeep Grand Cherokee Limited
Old 11-13-2012, 12:33 PM
Resident Technician
Rep:1915
They're right about the status of the M34. What is it you want done instead of rebuilding the rear end?
Old 11-13-2012, 12:55 PM
Turbovsix's Avatar
Rep:85
Their solution was to rebuild it, and not put the "retainer" on the pinion nut because they don't have access to the recall yet.
I'd like a new differential because I don't trust that they'll rebuild it correctly. I took my vehicle there a couple times when it was new because they gave me an oil change package (I normally do it myself but it was free so...) and they couldn't even manage to use the right oil and not get the inside of my vehicle greasy.
So, I don't really have faith that they'll rebuild it properly. If that's the best I'm going to get, then they at least need to add the retainer to the nut, which they can't seem to do right now because the recall is technically not announced yet.
Rich -
Old 11-13-2012, 01:51 PM
Resident Technician
Rep:1915
Understood. I would ask them to install some locktite until the recall comes out. This should help with the problem. I also understand your misgivings about them doing the work but keep in mind that the lube bay guys that did your oil change are not the same ones that would rebuild the differential in your truck.
Old 11-13-2012, 04:03 PM
Turbovsix's Avatar
Rep:85
I hear ya - good point. They have it torn apart right now but are waiting on a call from the Chrysler case manager to see how they are going to proceed. I guess I'd be more comfortable if there was a better way to retain the pinion nut other than loctite, know what I mean. I guess I don't have much chance of getting them to replace the whole unit with one from a 2011, huh?
Rich -
Old 11-13-2012, 04:43 PM
Rep:2890
I looked at the NHTSA ( National Highway Traffic Safety Association ) website & the
http://www.safercar.gov/ , both are Federal Government websites
at Safercar, you insert your vehicle info & follow the prompts
you will see that the file # is still open on the pinion nut
also if you follow the complaints by case or file number, the Q & A even goes so far as to name the number of complaints, the speed that it occurred at, & what the result was
check all the PDF files
http://www-odi.nhtsa.dot.gov/acms/cs...21&docType=INV
Old 11-13-2012, 08:09 PM
HD4's Avatar
HD4 HD4 is offline
Vehicle: 2014 1500 CC Sport 4x4
Rep:16
HD4 is on a distinguished road
Where in NJ are you? I'm in Cherry Hill. I had both 87 Turbo T and 87 GN bothe sold into boats now (bigger money pits!)
At what mileage did you start having the rear issues ? What dealer?
Mike
14 Ram Sport 4x4 CC loaded 13 Yukon XL Denali 15 JKU Willys 08' Pursuit 28 OS
Old 11-15-2012, 08:52 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Hi Ram Tech, I have a question directly related, my truck falls within the recall, I had a shop locktite and peen the edge of the pinion nut last spring for fear of what could happen. What do you think their reaction will be when they see the pinion nut peened in two places?
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 04-25-2013, 12:17 AM
Turbovsix's Avatar
Rep:85
Well I am now on diff failure #3 as of yesterday. Truck back in the shop. Christ I'm glad I don't tow the bass boat with this rig - I'd be on differential #9 now. This is failure #3 in 85k miles.
Waiting for verdict from dealer but betting on pinion bearing again.
Oh by the way I have my recall letter but no parts available yet. Hate everybody.
Rich -
Old 04-25-2013, 12:33 AM
Rep:2890
I received the RECALL letter yesterday
had my name & VIN# typed out in the notice
Strange thing is it specifically reads 3.92 ratio, i have the 3.55 ratio ???
It also reads that some Rams did not get the retainer patch that holds the pinion nut in position
