Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 12-14-2012, 07:46 AM
Hardware's Avatar
Hardware Hardware is offline
Trim Level: Outdoorsman
Color: Black over Grey
Rep:31
Well, connecting to the rockers would be okay if the load was spread out over more vertical area. The current mounting system has the each step attached with only two bolts close to the top of the arms so the tendency is to pull or rotate the bolts out and up (the sheet metal bulged out below the bolts).
Two attachment points per arm (total of four for each step), spread out over say, 8-10 inches vertically would likely solve this issue.
Old 12-14-2012, 06:02 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
If you get the longer ones that go wheel to wheel you get six mounting points. Mine barely flex with both my wife and I standing on the same step (375lbs combined)
Old 12-16-2012, 07:12 AM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
Are the side steps on the 2013s set up the same way?
Old 12-16-2012, 07:17 AM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
These new steps on the 2013s do use the same mounting locations and hardware as the 09-12s.
Chrome... in moderation.
Old 12-16-2012, 02:47 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Mine actually attach there and to the body mount bolts, they don't move at all. and there are plates they screw into behind the body wall. Very solid setup.
Old 12-16-2012, 03:53 PM
Vehicle: RAM
Rep:33
So is there really a problem for these side steps? I ordered the new wheel-to-wheel side steps for my 2013 regular cab, but now I'm not sure if it's a good idea... don't want to damage the sheet metal if that's the case.
Old 12-17-2012, 04:25 PM
Vehicle: RAM
Rep:33
So the guys that are having this problem are talking about aftermarket steps that they've likely installed themselves either without enough hardware or incorrectly... sounds like this problem isn't related to the factory steps.
Old 12-21-2012, 12:49 AM
Hardware's Avatar
Rep:31
Mine were the MOPAR stirrup steps, installed by following the directions to a T - right down to precise torque settings.
Old 12-21-2012, 01:03 PM
cgsjls cgsjls is offline
Vehicle: 2010 Ram 1500 TRX4 Quad Cab
Trim Level: TRX 4
Color: maroon
cgsjls is on a distinguished road
Wrong. My steps are the Mopar steps that come with the chrome package on the 2010 Rams. They are junk. Avoid them or expect issues.
Old 12-22-2012, 04:31 PM
JRBass JRBass is offline
Vehicle: 2010 Ram 1500 SLT 4X4
JRBass is on a distinguished road
My Dealer fixed mine under warranty when one of the broke free while someone was entering my truck. Instead of doing the OEM Rivnuts they welded in nutcerts. They said the problem is that alot of time the rivnuts are not collapsed enough.
