Old 11-14-2012, 11:47 AM
Ziegler00's Avatar
Ziegler00 Ziegler00 is offline
Vehicle: 2012 Ram Express Quad Cab 2wd
Color: Deep Red
Rep:13
Ziegler00 is on a distinguished road
Default Tire Help
2 different questions....
1) With stock suspension, whats the biggest tire that will fit without rubbing?
2) With 2 in leveling kit, is it the same size as stock that will fit? With wheel spacers on the front, can you go bigger? IF so, what size spacer?
THanks guys
2012 Ram 1500 Express Quad Cab 2wd
"The high cost of livin, aint nothin like the cost of livin high"
Old 11-14-2012, 06:22 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
THanks guys
33's with stock, some level kits you may be able to go up to a 35 i would not recommend it though, wheel spacers will let you run wider wheels not so much taller though.
hope this helps
