heater motor fail 90 cummings - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 11-14-2012, 02:06 PM
hypermax hypermax is offline
Vehicle: 1990 dodge ram
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
hypermax is on a distinguished road
Default heater motor fail 90 cummings
one day my blower motor stoped working on my 90 dodge cummins so i tested the blower motor, low-high switch, all the fuses under the steering column changed the resistor. and still no fan on any setting. i checked the plug for power at the blower motor in the engine bay and theirs now power goin to it.
and theirs no power goin to the resistor plug and i checked the plugs on the dash buttons for defrost and vent all that theirs no power goin to those plugs aswell, thats with the key on. the only relay i cand find on this truck is under the steering column its a [COLOR=blue !important][COLOR=blue ! important]3 [COLOR=blue ! important]prong[/COLOR][/COLOR][/COLOR] one and when i pull it out theirs power goin to the relay, i also pluged the raly back in and tested with the tester light from under neath and the horn goes off when you touch the one wire so i dont think this relay sends power so the blower motor or the dash buttons
if anyone can give me any direction with this it would be deepy apreachiated
Old 11-19-2012, 11:38 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Bad switch. Or if its like my 82 try moveing ignition back a bit if it works in on position but not after you have started it. The return spring is stuck on my ignition switch
