Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 11-25-2012, 12:37 AM
jkotis jkotis is offline
Vehicle: 1986 Dodge D150 Ram
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
jkotis is on a distinguished road
Default 1986 Dodge D150 Ignition Switch
I have the Dodge factory repair manual but I still cannot determine how to replace the ignition switch on my 1986 Dodge D150 Ram with power steering and no tilt wheel. I know the switch is in the steering column in the section that houses the gear shift lever. It is remotely operated by a rod connected to the steering lock. How do you replace the ignition switch? The problem is that you have to "giggle" the lock to get the blower to come on. I think the contacts on the ignition switch are bad.
Old 11-25-2012, 08:59 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
Haynes repair manual #30040 Dodge pick-ups 1974 thru 1993 has great drawings and explainations that should help you.
