heater/ac blower motor intermittently working - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-19-2012, 12:57 PM
Dano86 Dano86 is offline
Vehicle: 2004 ram 1500
Trim Level: HEMI sport group slt
Dano86 is on a distinguished road
Default heater/ac blower motor intermittently working
04 1500 5.7
Blower motor is intermittently working. Plugged in a new resistor and motor doesn't help. All wireing is good. Anything else to check before replacing control unit?
All help is greatly appreciated
Dano
Old 10-19-2012, 01:12 PM
Rep:1915
A melted ignition switch and connector is a common failure that will prevent power from making it to the blower motor. Check the dark blue wire at the blower motor connector with the key in the run position. You should have power and the connector should be clean and show no signs of melting. If you're OK here, pull the steering column covers and check the ignition switch connector for signs of melting. New switches and connector pigtails are available from a dealer.
Old 10-19-2012, 03:07 PM
Thanks for the reply! I will try that tomorrow
Old 10-20-2012, 02:26 PM
No power at the Blower motor but wires do not look melted
Old 10-23-2012, 03:30 AM
fireman21 fireman21 is offline
Vehicle: 2013 Ram Big Horn Quad
Color: deep cherry Red
fireman21 is on a distinguished road
not being a wise a$$ but did you check the fuse? first thing people over look sometimes yet its the easiest to check.
Old 10-23-2012, 09:17 AM
Rep:1915
Ordinairly a great idea, but there's not one to check with this setup.
Old 10-23-2012, 09:18 AM
Rep:1915
Did you check the dark green wire at the ignition switch yet?
Old 01-02-2013, 02:34 AM
cruzin55 cruzin55 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: larmie
cruzin55 is on a distinguished road
I have the same problem with mine and was told it could be a ecm going bad
