Battery cable question in custom s10 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Off Topic > Off Topic Discussion > Other Vehicle Discussion
Old 11-15-2012, 09:56 AM
slasher012's Avatar
slasher012 slasher012 is offline
Vehicle: 2005 Dodge Ram 2500
Color: Blue
slasher012 is on a distinguished road
Default Battery cable question in custom s10
I've got a 1991 s10 that I've got the battery in the bed near tailgate. I'm about to run the 1 gauge cable from the battery to the front of the truck which I then need to split to 2 wires. Can I just take the 2 wires and soilder them to the end of the main cable and wrap it good, or should I get something like a distribution block and crimp on ring terminals and connect them that way?
Old 11-15-2012, 11:26 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
I would do a distribution block myself. It looks cleaner and you have the option of moving the wires around.
Old 11-16-2012, 07:46 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Go with the distribution block, as stated above it looks cleaner. I also believe that you'll get a better connection... no matter how well you solder wires/ cable that large it's tough to get them to perfectly mesh up, unless you're able to properly weave them together.
I also think that the d-block will cut down on the heating up of the cable(s) under full load too. Heat and cables only combine so well, when they reach to the end of the tolerances it get real ugly, real fast
good luck
Exco
Bill
Old 11-16-2012, 10:30 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I don't believe solder would hold up well on that large a cable.
Sean
Old 11-19-2012, 10:19 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
I agree a block then put ends on.
Old 11-20-2012, 12:36 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
In high current circuits like what the Hydro companies work with, they never solder. All high current connections are crimped/clamped as that has proven to create the lowest resistance which equates to the highest reliability and lowest heat.
Your battery circuit is a high current circuit. I highly recommend using a proper crimp or clamp style connector and a distribution block. Both of which should be the ones designed for that current application.
brad
Interested in one of my mods?
