TPMS Problem - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-10-2013, 04:23 PM
2012 Race Truck's Avatar
2012 Race Truck 2012 Race Truck is offline
Vehicle: 2015 Ram R/T
Trim Level: R/T
Color: Deep Red Pearl
2012 Race Truck is on a distinguished road
Mine kicked on when I had a cold morning at 28psi. You have to fill them to 5 pounds over the psi on the door jamb. Then bleed them down to the correct pressure and drive a bit. The sensors aren't on when the truck isn't moving. I had the correct pressure for some time until I found out you need to reset the sensors and they aren't on unless you're above a particular speed.
Old 01-10-2013, 04:43 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Originally Posted by Al E. Gator View Post
What does it say is the correct pressure on your door sticker? Mine is 40, my TPMS comes on somewhere around 35.
If you have the 20" wheels, I believe the proper amount is 35 psi (cold). That is what the door sticker on my Laramie calls for. I think the 17" gets 40 psi.
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 01-12-2013, 12:22 AM
RogueRam RogueRam is offline
Vehicle: 2011 1500 Bighorn crew 4x4
Trim Level: Bighorn
Color: Charcoal
RogueRam is on a distinguished road
Originally Posted by drew7811 View Post
Has anyone noticed the accuracy between the dash tpms reading and what you actually get with a manual gauge? I have checked mine multiple times (cold and even warm for comparison) and found the computer is always 2-3lbs more than what I am getting on the manual tire gauge. I even used a seperate gauge and it shows the same. Has anyone else noticed this on theirs?
Mine seemed to be pretty much spot on with my gauge.
I think you have to bring them to at least 34 or 35 lbs to get the warning to reset.
Old 01-16-2013, 07:44 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
At 33 lbs, they should reset after driving for a bit as the tire pressure will go up when warm. That is what I ran on the rear of my 09 QC 1500 4x4 with 20" tires. Sticker said 35 lbs ft and rr.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
