Old 11-15-2012, 12:46 PM
otturious's Avatar
otturious otturious is offline
Vehicle: 2007
Color: Grey
otturious is on a distinguished road
Default Aftermarket Bump Stops???
I wanted to eliminate the dip in my rear while towing and hauling. Ive seen replacement blocks that look like an air ride. They just replace the bump stops above the axle. Anyone have them and how is it? I dont want go through the whole air ride. Because I dont haul and tow enough for that kind of investment.
Old 11-15-2012, 03:11 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
WIth your year model look at Hellwig or others for their helper springs. It's usually a 1/2 spring you add into your leaf pack to help with sagging when towing or loaded heavy. Cheap too...around a hundred bucks or so.
Old 11-15-2012, 03:36 PM
otturious's Avatar
Vehicle: 2007
Color: Grey
you wouldnt happen to have a brand to recommend?
Old 11-15-2012, 03:37 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
I'd start with Hellwig. I'm pretty sure they make them. Or just Google "1/2 ton truck helper springs"
