Old 11-17-2012, 11:40 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
You look down the thru the throttle plates, while holding wide open, with a flashlight, not running, of course. To do that, you only need remove the clamp holding the air tube, and move it aside. Oily bottom = gasket change, which I suspect you have awaiting you. I had a #1 and #8 misfire, the sensor detects the associated vibration & references the crank position sensor, to set codes, apparently. when mine went, I could keep the codes away by running , temporarily albeit, by disengaging overdrive.
Old 11-18-2012, 01:16 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
^ what he said. Removing the intake should take like 5 minutes if that.
Old 11-29-2012, 12:46 PM
Dcox01 Dcox01 is offline
Vehicle: 1998 Dodge Ram
Trim Level: None
Dcox01 is on a distinguished road
Default Same Problem Here
I had the exact same problem and changed the Tranny which didnt fix it.
Changed plugs and no wires. u really need to change those wires. My truck shuddered on the interstate at 70mph very bad and not as bad in 3rd at 45mph but it was still a shudder none the less. I changed Cap rotor pulgs and wires and it stopped. to find out if it is your wires, wait till dark where it is pitch black when u look under the hood of your truck. Start the truck and look for a arc or a spark traveling outside the wire or where the plug meets the distributor cap. If you see blue then you need to change the wires. I had a fouled plug and man was it filthy when i pulled it out which i attribute to a valve cover leak. When you took your plugs out what did they look like on the sparking side?
Changed the valve cover gaskets and now a slight shudder has came back.
Does anyone know how a plug keeps fouling out. If i ran a missing cylinder for awhile till i fixed it, when i put a new plug in should i have sprayed something in there before replacement?
Originally Posted by spadams View Post
Okay, will check gasket in morning and see if I can borrow a tool to get the codes. In the meantime:
-I didn't replace the wires when I did cap/rotor/plugs, was that a mistake?
-I'm due right now for an oil change and the engine is half a quart low - not sure if this is indicative of a leak though since that's been pretty normal for the last couple of years
EDIT: Oh also my repair manual doesn't mention a plenum gasket, does it go by another name?
Thanks for help all!
Old 11-29-2012, 01:35 PM
FilthyDog's Avatar
FilthyDog FilthyDog is offline
Vehicle: 1999 Dodge Ram 1500
FilthyDog is on a distinguished road
From what I understand the original plenum and plenum gaskets on these trucks were poorly designed. It's not a question of if, but when, they will fail.
Mods: Hughes FI Intake, Stainless Steel Short Headers(generic ebay), Rebuilt Cylinder Heads, K&N Cold Air Intake, IAT Mod, Hughes STAGE 1 MODIFIED O.E.M. THROTTLE BODY, High Flow exhaust, LineX Bed Liner
Old 11-29-2012, 01:43 PM
Rep:1909
The gaskets, yes. The pan, well, I've never seen a pan cause a problem. Hughes came up with a great "repair" by offering these kits. Wish I had thought of that.
flashing, shudder
