A/C Leak after Sparkplugs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-16-2012, 02:41 PM
hicruise55 hicruise55 is offline
Vehicle: 2010 Ram 2500 CC LB BigHorn
Color: Austin Tan Pearlcoat
hicruise55 is on a distinguished road
Default A/C Leak after Sparkplugs
When I was changing the sparkplugs on my '10 CC 2500 BigHorn I bumped, and I mean barely bumped the A/C line that goes to the junction box on the firewall and it lost all refrigerant I have a friend with guages ect. I changed the O-Rings on the engine side but upon re-charging found that the leak in on the INSIDE :'(
My question is: is there O-Rings on the inside or am I going to most likely have to change the condensor inside(line split)? Do I pull all those clips to access it? I am very mechanical but '10 is by far the newest vehicle i've turned wrenches on. What should I expect once in there? I have already unplugged the compressor as to not burn it up. I know it's now winter but want to fix this asap.
Thank you in advance. A
Old 03-25-2013, 11:03 PM
Mahadigus Mahadigus is offline
Vehicle: 2012 Dodge Ram
Color: Deep Cherry
Mahadigus is on a distinguished road
Evaporator for sure a guy I work with did the same thing on his first hemi tune
