Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
MOPAR DECALS
Old 11-17-2012, 12:28 AM
durb747 durb747 is offline
Vehicle: 1992 dodge 250
Trim Level: le
Color: red/grey
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
durb747 is on a distinguished road
Default Oops!
Newbie mistake! Posted my tech question in my intro. Anyway just thought I'd ask a question regarding my block heater. Just quit a few days ago so I bought a new cord but it turned out to be the element is NFG. I bought a new 750 watt block heater and have tried to remove old heater. Loosened the bolt under the plug etc. but it's welded in after 20 years. Any suggestions other than a bigger hammer? Thanks.
Old 11-25-2012, 09:36 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
Find someone with a knowledge of metal and a welder. They may be able to help you.
Old 11-25-2012, 09:55 PM
Rep:2875
soak it with PB BLASTER, its on the shelves next to WD-40 & Liquid Wrench
if that doesn't work, you will likely need heat, like a BernzOmatic nozzle with Propane or Map gas
