Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 11-18-2012, 02:13 PM
tmoswalt04's Avatar
tmoswalt04 tmoswalt04 is offline
Vehicle: 2009
tmoswalt04 is on a distinguished road
Talking Help in finding problem...
I have a 09' Dodge Ram 1500 (5.7 lt Hemi). While driving the vehicle, it just shut off and will not start. I have checked the fuel pump and the fuel pump is working properly. I know I am getting fuel all the way to the fuel rails on the engine. However, I do not think I'm getting fuel to the spark plugs because the spark plugs are completely dry and do not have any fuel smell to them. The engine rotates but does not seem like it is sparking. I have also hooked up an OBD II scanner but the only code I am getting on it is emissions. Any help in this matter would be very much appreciated. Thanks.
Old 11-18-2012, 05:13 PM
Rep:1845
Check for a Crankshaft Position Sensor signal. Without it, you won't have an injector pulse or spark.
Old 11-18-2012, 05:16 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
Vehicle: 2007 Ram 1500
Color: Gray
Rep:48
ShiftJockey is on a distinguished road
What code did you get?
Upgrading one part at a time.
Old 11-18-2012, 09:49 PM
tmoswalt04's Avatar
Vehicle: 2009
Talking How do I check...
(RamTech) How would I go about checking the Crankshaft position sensor signal? Would it still be located on the Bell Housing for the 2009? I just want to make sure I check the right part.
(ShiftJockey) The codes I got were P0440 and P0113.
As always I appreciate all the help. Thanks!!
Old 11-20-2012, 11:38 PM
tmoswalt04's Avatar
Vehicle: 2009
Ok, we replaced the Crankshaft position sensor and even reset the computer, but it still is not catching. So is there any other suggestions? This is getting really frustrating!!!
