Old 11-18-2012, 04:55 PM
patsac patsac is offline
Vehicle: 2004 dodge ram
patsac is on a distinguished road
Default milky stuff in filler
2004 4.7
changed the oil when i took the oil cap off to put in fresh oil in i noticed a milky stuff in the neck took a second look at the old oil . old oil was not milky
any ideas?
Old 11-18-2012, 05:02 PM
Rep:2616
I believe that is just a bit of condensation
i don't believe it is anything to worry about
clean off the cap, wipe off what you can of the milky stuff
& just keep an eye on it to see if it gets worse or stays milky in the same area
Old 11-18-2012, 05:23 PM
Rep:1845
Confirmed. It's just condensation and nothing to fret over.
Old 11-21-2012, 03:30 AM
Alaskan Hemisport Alaskan Hemisport is offline
Vehicle: 2011 Ram 1500
Alaskan Hemisport is on a distinguished road
I about had a heart attack when I went to do the first oil change on a truck I bought off craigslinst and the whole underside of the lid and the filler tube was completely gunked off with a yellow milky substance. But yes, its just gunky water that got sucked to the top of the system
Old 11-27-2012, 06:15 PM
dodgeramit
I had the same problem and thought it was condensation. ITS NOT TO BE IGNORED!! Im now in the middle of pulling apart the engine because of sludge, possibly caused by a bad pcv valve that cracked and let in air/water. The sludge is almost play-doh consistency. It got so hot from lack of lubrication that one of the bearing caps cracked. I am a former dodge dealer mechanic, and baby my vehicles (maint and dont drive like crazy). I am from FL, but Im stationed in MD and thought it was just because of cold weather. Boy was I wrong!
Old 11-27-2012, 06:25 PM
dodgeramit
I know its a lil bit of a pain, but pull off the passenger side valve cover and actually inspect for milky/ sludge in there. It'll def be worth it to find it now.
