Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Place your Ad Here!
Old 11-23-2012, 12:03 PM
sandawilliams's Avatar
sandawilliams sandawilliams is offline
Vehicle: 2014 2500
Rep:23
sandawilliams is on a distinguished road
Default tire wear
thumbuster2- You can and will experience unusual tire wear if- you are close to towing capacity, if your rear sags over a couple of inches, if you tow alot. I have towed my 33' Jayco 25000 miles since buying my 1500 new in 2009. I am close to max towing capacity when the trailer is fully loaded, (7240 vs. 7500 capacity). When the WDH is adjusted correctly I would have about a 3" squat in the rear. The rig towed and handled great but with new 10 ply tires I would experience cupping on the inside 2" of tread (rear) and the outside 2" of tread (front). This happened on my last long distance trip which was about 8000 miles. Since installing the rear air bags I was able to level the load out with just enough tongue weight to tow safely but not so much that it created a squatting of the rear.
Keep in mind that the tire wear is not real excessive without help in the rear but if you tow as much as I do the air bags pay for themselves in tire savings.
Old 11-23-2012, 06:50 PM
thumbuster2 thumbuster2 is offline
Vehicle: 09 Dodge Ram 1500
Trim Level: SL
thumbuster2 is on a distinguished road
Sandawilliams, you are right on the money and this is one of the reasons why I put the air bags in. Anytime you are loading close to capacity will cause strange things to happen to tire wear but that is usually related to the loading and not the angle of the truck. As you said, leveling out the truck to adjust rear/front loading is what is really the whole idea of the air bags. No matter what we add, we can not change the GVW of a vehicle. When in a DOT check they don't care what it is registered for but rather what the vehicle itself is rated for. My service truck was Dot regulated, 25000lbs, and after having to check in at many checkpoints over a few years ya really get used to what they are looking for, lol.
Keep the shiny side up and the fenders tween the ditches.
Old 11-26-2012, 09:51 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2016 Ram 2500 Crew Cab 4x4
Rep:89
APSTRAM will become famous soon enough
Originally Posted by seanbeckaroo View Post
I saw that, might go with 25% and see how that works. I don't have a real heavy camper, only about 4500# loaded up; so the 25% might be the way to go for me. I haven't even tried towing yet, my camper is put away for the winter already
I spoke to Randy at Otto-Max about their TufTruck TTC-1223V variable rate springs today and he stated they will run somewhere between 30-35% and will be stock height and near stock ride due to the variable rate. I may just be ordering these for my truck.
Old 12-02-2012, 03:59 PM
APSTRAM's Avatar
Rep:89
I installed the TufTruck TTC-1223V springs today. The sag I had when towing my snowmobile trailer is no longer a problem. The ride is good and there is a bit of a rake again even with the bilsteins set at 2.1, I hope the springs will take a set after a bit and the truck will be more level again.
Here are some Photos.
Before
After
Unloaded
Old 12-02-2012, 05:29 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:207
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
How dose the truck ride now with the TufTruck springs?
Old 12-02-2012, 05:38 PM
APSTRAM's Avatar
Rep:89
Truck has a nice ride still but that is probably due to the bilsteins in the front and rear.
Old 12-03-2012, 09:18 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
Before
Attachment 31957
After
Attachment 31958
Unloaded
Attachment 31959
Great info, and thanks for the Pictures.
Old 01-07-2017, 06:04 AM
Synolimit Synolimit is offline
Vehicle: 2017 Sport Quad
Trim Level: Sport Quad
Rep:15
Synolimit is on a distinguished road
APSTRAM,
Still on here? How's the rear springs after these years?? I set my 5100's to 2.1" also but I added a 0.75" rear lift. OEM is roughly 2.75" rake and right now I'm 1.4" rake. I really don't want to sag when towing and right now the ride quality of the 5100's front and rear is awesome!
Old 01-07-2017, 05:19 PM
barr0208 barr0208 is offline
Vehicle: 2016 Dodge ram1500 laramie
Trim Level: laramie quad cab
Color: ruby red pearl
Rep:16
barr0208 is on a distinguished road
go with the tuff truck 1223v springs they are variable rate springs and the ride is not affected that way it gives you the max capability 50% more weight than stock.
Old 01-08-2017, 06:20 PM
Rep:15
Thought it was 35%?
