Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Old 11-19-2012, 10:25 AM
Dhawk13's Avatar
Dhawk13 Dhawk13 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Silver with Blue Pearl Flamed Clear Coat
Dhawk13 is on a distinguished road
Default Ford Taurus Electric Fan Swap Questions!??
Hey guys i was reading around a couple forums on the Ford Taurus electric fan swap to replace the clutch driven fan.. Well I have a few questions before i do this.
1) What year model Tauruses have this electric fan i can use?
2) What are the benefits of doing this mod?
3) Are there any cons of doing this?
4) Is there somewhere i can go online to tell me how to do the swap?
Thanks for your time, Dhawk
Just drag it!
Old 11-19-2012, 11:30 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
The early '90's with the 3.8 had the correct fan. Not sure of years, perhaps 91-93? Has to be the 3.8.
You'll gain a bit of power by removing the clutch fan, but IMHO, it's not worth it. The wiring can be tricky, even for experienced mechanics, and controlling the speed is another issue; both due to the amount of current the fan draws. I found that a two-speed Volvo relay worked well for the high/low speed operation, but you'll still need to figure out how to trigger it.
Ultimately, you'll free up a few HP; but you'll lose the reliability of the factory e-fan and clutch fan.
I did the swap on my '02 Durango and '02 Dakota. Gained 1 mpg on the Dakota, nothing on the Durango. Best part? No clutch fan roar. Worst part? No real benefit for all the work.
There are lots of how to's on the web, some from downright scary (such as using a solenoid as a relay), to excellent.
Old 11-19-2012, 11:32 PM
Rep:154
Here's a good link:
http://www.nastyz28.com/forum/showthread.php?t=225174
Old 11-20-2012, 12:51 AM
Dhawk13's Avatar
Thanks a bunch! Do you happen to know if it will throw a engine code when i put the 180 degree thermostat. I was wondering because thats what some of the forums are saying to do with the swap.
Just drag it!
Old 11-20-2012, 11:46 AM
Rep:154
No, you shouldn't have any issues with a 180* thermostat and throwing a code.
Some people have had this issue if they live in a cold climate, but it's somewhat more rare than commonplace, even in the cold climates.
Old 11-20-2012, 01:00 PM
Dhawk13's Avatar
Okay thanks a bunch!
I plan on getting the fan, the haynes controller, 180* thermo, and more wiring.
Is there anything else i need before i start?
I saw some people were saying to use a bigger relay. Do you know what size relay would be best?
Just drag it!
Old 11-20-2012, 03:17 PM
Rep:154
I went with the volvo two-speed relay for the fans, and a 60a relay for the ignition (so the fans would not run without the ignition on).
I have not heard good things about the Haynes controllers and longevity on the taurus fan.
You're starting to see why the taurus fan is such a PITA...
Old 11-21-2012, 08:03 PM
HemiLonestar's Avatar
Rep:274
You may lose A/C effectiveness at low speed. My truck will turn into an icebox even at idle, whereas my wife's Jeep with just an electric fan won't get decently cold until you get moving at speed (which is why she is getting the heavy duty cooling kit with clutch fan).
"Big Red"
2006 Charger R/T
