No power? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 11-19-2012, 03:23 PM
Metallifan Metallifan is offline
Vehicle: 2001 Dodge Ram SLT
Trim Level: SLT Laraime
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
Rep:28
Metallifan is on a distinguished road
Default No power?
I have a 2001 4WD Ram 1500 Ext Cab with the 5.9L.
Just replaced my trans myself with a used one from a 97. Came with a transfer case attached, so I just used it. I had to swap out all the governer pressure sensors and solenoids and overdrive sensors and solenoids on the valve body because the 2000+ models use different ones. I got new ones, not from my old trans.
So, I did all that. This trans slips during second, just like my old one... Awesome. Anyway, with my old trans, I could still hammer on it and it would go just fine. Just how a big V8 should feel. But after I've put this trans in, If I try WOT from a stop or during second gear, it moves barely any faster, but the motor sounds like it's wide open. It does not feel like a slip. It feels like it's catching and the motor sounds like it's open, but it just has no go. WOT during 3rd or 4th feels as it should, plenty of power.
The throttle cable is very loose, but I don't know how to adjust it. I doubt it, but could it be it? Or is the trans about to implode right after I bought it? I replaced plugs, cap, rotor, wires because they were due anyway. No change. Trans fluid level is fine.
I have CEL for both O2 sensors. Don't even have them hooked up because they're both bad. Don't think this is the cause because I did the same thing with my old trans.
Any suggestions or thoughts?
Old 11-21-2012, 05:37 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Well I can help you out with the transmission issue which is what seems to be the center point of the problems. Anyways the no or slipping 2nd gear can be cause by many things, from a simple band misadjustment to the famous leaking direct clutch inner seal which.
Some of the things you should do first is check to make sure the band is adjusted proper, the front band, this is for 2nd gear. Make sure the strut and anchor didn't fall so on. Next thing you might consider doing is replacing the front servo assembly from sonnax or atleast the cover from sonnax, the stock cover leaks between the cover and the pin so you end up with a long slide 2-3 shift and sometimes but rarely no 2-3 shifts. But like I said it is rare. The worst case is a seal leak that causes no 2-3 shifts or a slipping/delayed 2-3 shift. But normally if that seal is leaking bad enough you will slip in reverse that is if you even have a reverse gear at that point. So just start out with the band adjustment, you can find directions all over the web on adjusting that band. And if you have any questions just ask away
Old 11-22-2012, 12:04 AM
Rep:28
I've found if I try WOT from a stop, it shifts 1-2 fine, but doesn't shift 2-3 at all, just redlines until I let off the gas, then it shifts immediately. I took the valve body off to get to the overdrive solenoid harness and the band anchor was still there and the band felt tight, so I didn't touch it. The anchor fell off on my old trans and I ran like that for 2 months, still had 2nd gear. Don't ask me how in the hell I did, because I don't know. Band was COMPLETELY loose, but it somehow still worked. Didn't find out till I dropped the old trans out. Lol. Isn't the adjustment for that band on the outside of the trans case? Reverse is fine. I've noticed that it always slips into 2nd after I do a WOT, too. And it actually had power like it should twice today. I've just been trying little bouts of WOT to see what it does. I'd like to be able to get moving on the highway if I need to. I'll try adjusting that band tomorrow. Just bought myself an inch pound torque wrench. How hard is the servo to replace?
Thanks for the help.
Old 11-22-2012, 01:12 AM
ramvan2500's Avatar
Rep:141
Well if the band and is all good then it's probably the servo or the seal, if reverse works perfectly then it's less likely the seal BUT THAT DOESN'T ELIMINATE IT. The front band adjustment is outside the case and the rear band is inside the transmission. But you don't have to adjust the rear band often, almost never because you only use the rear band in MANUAL 1st gear and reverse and well you only use reverse for a short hair second and you use manual 1st almost never. The servo is extremely easy to replace, you have to remove the pan but it is as easy to replace as an oil filter. You just might need a 8" c-clamp. You can replace the cover which is like 35 bucks or the entire servo for about 120, this is the parts cost for sonnax. I recommend you just replace the entire servo because that replacement servo has 15% more area for a much firmer 2nd gear.
If it is the seal which I don't mean to hurt you, seems like it may be a seal based on the way you describe how it won't shift until you let go of the gas. But if it's the seal that is a easy job to replace it, just have to remove the transmission, trans pump, then remove the front band, direct clutch, then take off the clutch piston retainer, then springs, then finally you remove the piston and replace seal and do reverse operation. being sure to replace pump gasket and seal.
Old 11-22-2012, 01:40 PM
Rep:28
Thanks.
Got a link for the servo assembly?
Shifted fine today, no slips or anything. I don't get it...
Old 11-22-2012, 02:59 PM
ramvan2500's Avatar
Rep:141
Thanks.
Well just because it shifted fine today doesn't mean the problem is gone, temperature and altitude along with pressure makes differences in operation.
Here is a link to the part, manufacture link
http://www.sonnax.com/product-lines/...ion/parts/3279
The part number is on there site, you can use a search engine to find a retailer by using that part number, every retailer sells at a different price so I'm going to leave price matching up to you.
Old 11-22-2012, 07:24 PM
Rep:28
I know. I'm just saying I can't believe how temperamental it is.
Thanks for the link.
Old 11-22-2012, 07:48 PM
ramvan2500's Avatar
Rep:141
Not a problem, more than happy to help. Yes temperamental indeed, but it isn't uncommon and many times things seems to be temperature related. But every chrysler transmission that is based off the immediate design of the 727 will have issues with 2nd gear sooner or later. And they all end up leaking at the servo, Chrysler never made any lengths to design a o-ring into the servo cover but most people don't keep vehicles long enough to anymore to the point they would experience issues.
