99 ram 2500 lift ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-20-2012, 12:01 AM
Racingredneck329 Racingredneck329 is offline
Vehicle: 1999 ram 2500
Trim Level: Slt
Color: Burgundy
Racingredneck329 is on a distinguished road
Default 99 ram 2500 lift ?
Can I put a tuff country 6" lift for a 2002-2008 ram 2500 on my 99 2500?
Old 11-20-2012, 06:53 AM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
probably not, however i do have a couple of options that will fit.
first=$1490
Part Number: SKYD501K-N
5 Inch Lift Kit with shocks
Lift Height: 5 inches
Front Lift: Coil Springs
Rear Lift: Rear Add-A-Leaf
Front & Rear Nitro Gas Charged Shocks W/ Shock Boots
Includes:Upper & Lower Link Arms & Relocation Brackets / Track Bar Bracket / Sway Bar Bracket / Pitman Arm / Brake Lines / Bump Stops
Max Tire Size:35 X 12.5
Wheel Size:15-16 X 10
Backspace: 4.625
Skyjacker offers a huge range of lift heights and levels of performance for most Chevrolet, GMC, Dodge, Ford, Jeep and Toyota vehicles. Go beyond the basic lift kit and get into a Skyjacker performance suspension package! Skyjacker Suspension products are the result of more than 35 years of new product engineering and innovation. We take pride in every product that we design, test, and sell. The suspensions we manufacture are for the vehicles you drive.
second=$1860
Part Number: SKYD501KS-N
Rear Lift: Rear Leaf Springs W/Lift Blocks
Backspace: 4.625
third=$1860
Part Number: SKYD501KS-SX-N
Backspace: 4.625
fourth= $1790
Part Number: SKYD502K-N
Backspace: 4.625
fifth= $1590
Part Number: FABK3007
5.5 inch Performance System with Performance Shocks
Lift Height: 5.5 inches
Front Lift: Upper & lower control arms and coil springs
Rear Lift: Lift Blocks w/U-Bolts & Add-A-Leaf
Includes: Trac bar relocation brackets,Bump stop spacers and more
Steering Correction: Pitman Arm
Shocks: Front & Rear Twin Tube Performance Shocks
Shock Boots: Not Included
Component color: Black
Max Tire Size (Inches): 315/75R16
Max Wheel Size (inches): 16x10
Backspace: 4.625
Fabtech's 5.5 inch Performance System for 1994-02 Ram 2500's provides increased ride height with additional wheel travel and articulation. The upper and lower control links are replaced with extended length 1 3/4" OD link arms and heavy duty frame brackets that utilize 5.5" tall coil springs for outstanding on and offroad ride. System also includes a Trac Bar relocation bracket, Pitman Arm, Bump Stops and more. Rear lift includes a Block and Add-a-Leaf combo. Other options include a front Multiple Shock System for hardcore offroad use. Use 315/70R16 tires w/ 16x10 wheels w/ 4 5/8” BS w/ minor trimming
Thanks
Jeremiah Hinkle
Discount Auto Performance
855-432-3278
discountautoperformance.com/store
sales@revelperformance.com
Old 11-20-2012, 11:19 AM
Trim Level: Slt
Color: Burgundy
Thanks I was only asking because I can get the lift for $300 used with shocks.
Old 11-20-2012, 01:42 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
That's not a bad deal, like I said probably won't work but I'm sure someone will chime in soon with a definite yes or know, let us know now you cone out
Old 11-21-2012, 02:57 PM
Trim Level: Slt
Color: Burgundy
Anyone else know for sure if it'll work or not?
