Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 11-20-2012, 07:36 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Default 911...help a brother out
I'm stumped on this one. I swapped in a SSBC front big brake kit today and matching rear rotors. It's a straightforward swap up front....remove the calipers as a unit, swap rotors, install new calipers as a unit. No sensors were touched and all wiring looks to be fine to the eye. Same for the rear...simple rotor swap...nothing out of the ordinary. Here's the issue....the stability control light on the lower right of the dash is on and the damned brake lights are stuck on. If I knew what sensor or issue would cause that I could fix it a lot quicker.... Any help is appreciated.
Old 11-20-2012, 11:35 PM
I push the skinny pedal
Rep:3308
ABS sensor probably, any codes pop up or are stored? Tried resetting the computer yet?
Kurtis
