United Radio
Old 11-22-2012, 01:04 AM
jbarr77 jbarr77 is offline
Vehicle: 2011 Ram 1500
jbarr77 is on a distinguished road
Those in dash touch screens are almost the size of an ipad. Eventually it probably will be.
Old 11-22-2012, 12:46 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
Originally Posted by craigsez View Post
I discovered today that the 13's have the air bag suspension that you can raise and lower...How much i dont know but i dont imagine its much more than a cpl inches..Cool options for those dry or snow filled roads..
I haven't seen one with the air suspension yet but I know their out there. It works just like the grand cherokee. Heres what chryslers dealer connect says about it:
Manual Control: An up and down switch is located on the center stack for driver control of the system. When the driver presses the up and down switch to manually raise or lower the vehicle height the Electronic Vehicle Information Center (EVIC) displays a vehicle “up” or “down” message icon and a LED indicator on the switch changes position. The EVIC displays the current position of the vehicle when it is achieved. When lowering the vehicle, the front is always first to move. When raising the vehicle, the rear is always the first to move. When the ASCM receives a command to change the vehicle more than one ride height position the action is performed in multiple steps. If request to change by two positions the rear will raise one position, then the front will raise one position, the rear again raises one position, then the front will raise to the final position. If requested to lower more than one position the same steps happen, EXCEPT the front moves first. This multi-step motion controls the angle the headlights are projected by controlling the pitch of the vehicle, keeping them from going above their normal projection plane.
There are five predetermined manual height settings; Normal Ride Height (NRH), two above and two below NRH. The predetermined vehicle heights (above or below NRH) are as follows:
Off-Road 2 (OR2), + 51 mm (2.0 in.)
Off-Road 1 (OR1), + 30 mm (1.2 in.)
Aero Mode, - 28 mm (–1.1 in.)
Entry/Exit Mode, - 53 mm (–2.1 in.)
NOTE: The air suspension system will auto-disable when lifted on a frame hoist, or when jacking one corner of the vehicle. The air suspension may attempt to change height slightly prior to switching to auto-disable. A manual disable is also available by pressing the “Up” and “Down” switches of the terrain select switch simultaneously for more that 5 seconds. The air suspension system will return to normal operation when the vehicle speed reaches 25 kph (15 mph).
Sadly you can't put it into off road 2 and drive around with a 2" lift, unless you never go over 15mph...
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 11-22-2012, 03:37 PM
P-Rez's Avatar
P-Rez P-Rez is offline
Rep:28
P-Rez is on a distinguished road
how much are those sports running for? i want a crew cab with 6'4, so ill have to wait
P-Rez
Old 11-22-2012, 03:50 PM
Rep:73
the one I posted has a sticker of $45,000
Check em' out:
Old 11-22-2012, 06:30 PM
dalonzo96 dalonzo96 is offline
Vehicle: 2013 dodge ram
Trim Level: sport
dalonzo96 is on a distinguished road
Originally Posted by Yqm View Post
Here are a few others....Attachment 31768Attachment 31769
Do you have a larger picture of that black sport? I will be purchasing a black sport and wanna do something like that truck and wanna see how the new trucks look lifted.
Old 11-23-2012, 05:12 PM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
Originally Posted by frickenbored View Post
Thought I'd post a couple pics of one of the nicer 2013 ram's I've seen so far, we just got this in at work today:
Fully loaded 4x4 sport, with the r/t hood and black projector headlights. Sticker price: $45,000
I don't like the chrome, the new headlights, or the r/t hood... I think the Express looks way better.
Old 11-23-2012, 05:36 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
mine stickers at $38,200 but is not 4x4 and is a quad cab
SOLD: 2012 Ram 2500 CTD 4x4
Old 11-23-2012, 09:03 PM
That's the first time I'm heard that
Old 11-24-2012, 04:27 PM
Vehicle: RAM
Rep:33
The exterior of the Express and the Sport look the same except for the things I mentioned I didn't like (Chrome grille, HID/LED lights, R/T hood), so it's not exactly a shocking revelation hahaha!
I should've said "better" and not "way better" too... since they look so alike.
Old 11-24-2012, 06:04 PM
Hahaha.
I got you the first time....just yanking your chains.
But then again, it helps when you own an express vs a sport and vice versa for those who own a sport
